$409.99
Original price $409.99 - Original price $409.99
$409.99
Current price $409.99
Puli AX (GL-XE3000)
GL-XE3000 Secure Remote VPN Connectivity
Meet Puli AX
Wi-Fi 6 5G Cellular Router with Battery
Portable Wi-Fi 6 5G NR Router
Puli AX (GL-XE3000) is the ultimate Wi-Fi 6 5G Cellular Router that takes your internet speed to the next level! With a powerful built-in 6400mAh/7.4V/47.4Wh battery, you can now enjoy uninterrupted internet connectivity for even longer periods. Experience lightning-fast Wi-Fi speeds of up to 574Mbps (2.4GHz) and 2402Mbps (5GHz), with a combined maximum Wi-Fi speed of 3000Mbps. It is equipped with a 5G NR cellular connection, ensuring reliable Internet connectivity, even in the event of an Ethernet failure.
Max. 574 Mbps (2.4GHz) + 2402 Mbps (5GHz) Fast Wi-Fi Speeds
OpenVPN speed up to 150 Mbps; WireGuard speed up to 300 Mbps
Dual-SIM, Single Modem
Built-in 6400mAh/7.4V/47.4Wh battery
Learn More View Online Guide
Module: RM520N-GL
5G NR NSA n1/ 2/ 3/ 5/ 7/ 8/ 12/ 13/ 14/ 18/ 20/ 25/ 26/ 28/ 29/ 30/ 38/ 40/ 41/ 48/ 66/ 70/ 71/ 75/ 76/ 77/ 78/ 79
LTE LTE-FDD B1/ 2/ 3/ 4/ 5/ 7/ 8/ 12/ 13/ 14/ 17/ 18/ 19/ 20/ 25/ 26/ 28/ 29/ 30/ 32/ 66/ 71
LTE-TDD B34/ 38/ 39/ 40/ 41/ 42/ 43/ 48
LAA B46
UMTS WCDMA B1/ 2/ 4/ 5/ 8/ 19
GNSS GPS/ GLONASS/ BDS/ Galileo/ QZSS
Reliable and Uninterrupted Internet
Puli AX (GL-XE3000) is equipped with advanced features, including Multi-WAN, Load-balancing, and Failover, to ensure users experience quality internet connections when traveling in both rural and urban areas.
Smart Charging & Battery Protection
  • Temperature control: Automatically stops charging at extreme temperatures (≤0°C or ≥50°C), resumes when safe.
  • Efficient charging management: Auto-stops after full charge to protect the battery.
Puli AX is pre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. It automatically encrypts all network traffic within the connected network, including guest or client devices that are not capable of running VPN. Puli AX can also host VPN servers and supports VPN Cascading, automatically forwarding data from its VPN server to the VPN client within the same device.
WireGuard
Max. 300Mbps
OpenVPN
Max. 150Mbps
Experience seamless connectivity with the Puli AX, fully compatible with GL.iNet’s advanced eSIM solution, which supports both physical eSIM cards and integrated eSIM chips*. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security. For consumers, this means effortlessly switching networks and avoiding roaming charges, while businesses benefit from centralized management, multi-device support, and secure data management.
*The feature currently requires pairing a physical eSIM card with our firmware. Integrated eSIM chip is available for bulk orders only.
DFS Certification in US, CA, EU and UK
Puli AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications. The selection of additional channels can lower network congestion under high density network environments.
Remote Access and Management
Puli AX comes with GL.iNet's GoodCloud remote device management platform, providing users with data usage monitoring and technical support services with remote access to the device admin panel for maintenance and troubleshooting. It also enables batch device management, firmware updates, analytics and notifications for status updates, enabling users to manage devices efficiently.
Model Comparison
Puli / GL-XE300
4G LTE Smart Router
VS
Puli AX / GL-XE3000
Wi-Fi 6 5G Router
Qualcomm Atheros, @650MHz CPU MediaTek Dual-core, @1.3GHz
DDR2 128MB / NOR Flash 16MB + NAND Flash 128MB Memory / Storage DDR4 512MB / eMMC 8GB
IEEE 802.11b/g/n Protocol IEEE 802.11a/b/g/n/ac/ax
300Mbps (2.4GHz) Wi-Fi Speed 574Mbps (2.4GHz), 2402Mbps (5GHz)
10/100Mbps Ethernet Speed WAN Port: 10/100/1000/2500Mbps
LAN Port: 10/100/1000Mbps
1 x WAN, 1 x LAN Ethernet Ports 1 x 2.5Gbps WAN, 1 x LAN
Type-C, 5V/2A Power Port DC5521, 12V/2.5A (5.5*2.1mm) [default adapter] / 9~16V
3.7V/5000mAh/18.5Wh Built-in Battery 7.4V/6400mAh/47.4Wh
1 x Nano SIM card slot SIM Card Slot 2 x Nano SIM card slots
Max.10Mbps OpenVPN (Via Ethernet) Max.150Mbps
Max. 38Mbps WireGuard® (Via Ethernet) Max. 300Mbps
Puli AX (GL-XE3000) Reivews
  • Video 0
    Best SIM Routers of 2023 - GET IT RIGHT FIRST TIME!
  • Video 1
    THE ULTIMATE SIM ROUTER DOES EXIST - The GL.iNet Puli AX Mobile Router Review
  • Video 2
    I have 5 hours to fix the gaming mini van
  • View More
5G NR Module
5G NR
Module
Mobile App Support
Mobile App
Support
Wi-Fi 6
Wi-Fi 6
VPN Client/Server
VPN Client /
Server
AdGuard
AdGuard
Dual-SIM
Dual-SIM
External Storage
Built-in Battery
(6400mAh/7.4V/47.4Wh)
DFS
DFS
The cellular feature in Puli AX (GL-XE3000) is restricted in Russia, Belarus, Cuba, Iran, North Korea, Syria, and the Crimean Peninsula due to modem limitations.
Specifications
1 x LAN Ethernet port
1 x USB 2.0 port
1 x MicroSD card slot (Max.1TB)
1 x Reset button
Memory / Storage DDR4 512 MB / eMMC 8GB
LAN Port: 10/100/1000 Mbps
Antennas 4 x Cellular Antennas (SMA, 600M~6GHz)
2 x Wi-Fi Antennas (PR-SMA, 2.4G~2.5GHz, 5.15~5.84GHz)
LEDs Power / Battery / Internet / 2.4G Wi-Fi / 5G Wi-Fi / Signal Strength
Power Input DC5521, 12V/2.5A (5.5*2.1mm) [default adapter] / 9~16V
Power Consumption <14W
Storage Temperature -20 ~ 45°C (-4 ~ 113°F)
Dimension / Weight 155 x 95 x 49mm / 761g
Contact Our Sales Team
Frequently Asked Questions
Overall rating: 4.940594 / 5 from 101 reviews.
AI Generated Review Summary
The Puli AX (GL-XE3000) is a Wi-Fi 6 5G Cellular Router with a built-in battery, offering impressive features, exceptional support, and fantastic connection speeds. It ensures reliable and uninterrupted internet connectivity with advanced features like Multi-WAN, Load-balancing, and Failover. The router is also compatible with GL.iNet’s eSIM solution and runs on GL.iNet's proprietary firmware based on OpenWrt.
Summary topics
  • Router Features (8%): Customers expressed appreciation for the impressive features of the router, with many mentioning its great build quality and technical features.
  • Customer Support (6%): Customers appreciated the exceptional support provided by the company, which was mentioned multiple times in the reviews.
  • Connection Speeds (9%): Customers expressed appreciation for the fantastic connection speeds and stable operation of this mobile cellular router without any issues.
Review topics: ["delivery","value","battery","price","support","speed","features","works","service","connection","interface","use","setup","performance","functionality","router","power","wifi","instructions","device","hardware","signal","unit","configuration","internet","machine","option","coverage","sim","firmware"].
Review highlights
  • "Very fast delivery and router has good feature set" — JOHN R.
  • "Fantastic device with virtually unlimited feature set." — Ward M.
  • "Very unique device, and excellent support!" — Ahmed
Reviews
Excellent option for event management
"Bought one for our scoring and streaming setup. works great, configuration options provide excellent flexibility and the battery is a life saver."
— Ignacio L. (5/5)
So far so good
"Just got the device booted up and running. Everything seems awesome so far. SIM card install was easy. Admin interface is straightforward. Options are easy to configure."
— Tony F. (5/5)
The perfect remote work companion
"As a freelance worker, I was looking for a reliable router that would deliver fast internet access wherever I went, no matter how the conditions were. And that includes remote locations where electricity is only available from a generator at nighttime. I bought the Puli AX router based on these premises and it has delivered flawlessly. The wifi signal is strong, allowing me to position the router for best connectivity. I use the two SIM card trays by getting cards from two different carriers in the country I travel to, so that coverage is optimal and redundant. And I can use either the Wifi or ethernet connection from the place I work from. All of this on a battery that can last a day's work. Add the flexibility of the software setup with the possibility to install your favorite VPN or other network related tool that helps you secure your connection and you've got a portable office that's as capable as the one at your headquarters. I've traveled to several countries with it, worked from a car on the highway, from a boat, from a train. I worked on a remote island, in the mountains and the countryside with nothing but woods and prairies around me, and every time I had the internet access I needed to get work done. Add to that a top notch support service and you have the most effective network tool for remote workers, or when you're how, to have a backup access point that will not go down when your internet box or electricity go down. This product is not for anyone, but if you're a power user/ digital road warrior, this is without hesitation the one and only router you need."
— Aldric G. (5/5)
Riley is the START again 2nd time
"This is the second time Riley has helped me. This time I was abroad, and Riley helped me with my travel and home router. I was glad that I managed to connect with Riley again. As usual, she is very knowledgeable and resolved my issue with great patience and support. Riley, you are a Star."
— Chiran (5/5)
Tailscale VPN.
"Great product, especially when used with Tailscale VPN. Setup was straightforward, and it works very well as an Exit Node. Customer support is excellent—they respond quickly and are genuinely helpful when you have questions or run into issues. Highly recommended!"
— Mathijn E. (5/5)
Fast shipping. Amazing customer service
"Customer service is amazing. They are quick to respond. My order was damaged in transit but customer service was very helpful and kind enough to send me a replacement. Will update the review once I have started using the device"
— Kelly (5/5)
Perfect
"In 2026 the wifi hardware is a bit falling behind but this unit is very stable and reliable. I like having the micro sd card slot, and the full support of open WaRT, Luci and Von clients. Very good what what I need"
— Steve S. (5/5)
Top Notch Customer Service and Router
"This router has been perfect for my RV adventures. After about a year, the battery needed to be replaced, and customer service really stepped up. They took the time to understand the issue, and it genuinely felt like they cared. After building some rapport, they ended up sending me a full replacement without any hassle. Great product and even better support!"
— Nghia (5/5)
Reliable router
"Use it as for home internet, great router/modem."
— Anton (5/5)
Awesome
"I love it"
— Guest C. (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
