$179.99
Original price $179.99 - Original price $179.99
$179.99
Current price $179.99
2025 Muse 2026 Red Dot
Comet Pro (GL-RM10)
Wi-Fi 6 Remote KVM with Touchscreen
Quad Core CPU
32GB eMMC
1GB DDR3L Memory
Touchscreen Display
4K@30FPS
Wi-Fi 6
4K Video Passthrough
Wi-Fi 6
Unleash mobility, free from Ethernet cable
2.22-inch Touchscreen
Quad Core
CPU
32GB eMMC
DDR3L 1GB
Ultra-low Latency
Gigabit LAN (1Gbps)
Self-hosted Server
Why Do I Need a KVM
Why Do I Need a KVM
The Comet Pro
Wi-Fi 6
Comet Pro is the first desktop KVM device to support both 2.4GHz and 5GHz Wi-Fi bands. Connect your GL.iNet Comet Pro (GL-RM10) to your Wi-Fi network without needing a LAN connection, redefining flexibility in remote access. Users can now manage systems without the need to connect physical network cables, unlike traditional KVM solutions. Additionally, the Comet Pro allows for network failover with both Wi-Fi and ethernet capabilities to improve your uptime stability.
Dual Band Wi-Fi 6
Total System Control
Accessories
PoE Splitter
PoE Splitter
Travel Case
Travel Case
TechRadar
TechRadar
Comet Pro Product Reviews
    I NEEDED to Fix her Internet!
What Beta Tester are Saying
slide 4 to 6 of 4
Compare KVM
Home Lab Comet (GL-RM1)
Comet
 (GL-RM1)
KVM over Internet
Comet PoE
 (GL-RM1PE)
KVM over PoE
Comet Pro
 (GL-RM10)
KVM over Wi-Fi 6
Display
4K@30FPS
4K@30FPS
4K@30FPS
Latency Latency
Latency Latency
30-60ms*
Latency Latency
30-60ms*
Latency Latency
30-60ms*
Two-way Audio Two-way Audio
HD Passthrough HD Passthrough
Display Screen Display Screen
2.22" touchscreen
System & Connectivity
Processor Processor
Processor Processor
Quad-core Cortex-A7
Processor Processor
Quad-core Cortex-A53
Processor Processor
DDR3L 1GB / 8GB eMMC
DDR3L 1GB / 32GB eMMC
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
2.4GHz: 286Mbps
5GHz: 286Mbps
LAN Port LAN Port
LAN Port LAN Port
1Gbps
LAN Port LAN Port
1Gbps
LAN Port LAN Port
1Gbps
Power Input Power Input
Type-C, 5V/2A
Ethernet (PoE) / Type-C,
5V/2A, PD-compatible
Type-C, 5V/2A,
PD-compatible
Dimensions Dimensions
80 x 60 x 17.5mm / 85g
102 x 70 x 22mm / 140g
93 x 84 x 47mm / 170g
Wi-Fi 6
Wi-Fi 6
4K@30FPS Video Resolution
4K@30FPS
Video Resolution
H.264 hardware encoding
with 30-60ms latency
BIOS Access
BIOS Access
USB 2.0 External Extension
USB 2.0
External Extension
Two-way Audio
Two-way Audio
APP or Browser Access
APP/Browser Access
Gigabit Ethernet
Gigabit
Ethernet
Technical Specifications
Operating System Linux 6.1
CPU Quad Core ARM Cortex-A53
Resolution 4K@30FPS
1x Gigabit Ethernet port
1x HD In
1x HD Out
1x USB 2.0 Type-A
Frequently Asked Questions
Overall rating: 4.868421 / 5 from 38 reviews.
AI Generated Review Summary
Summary topics
Review topics: ["service","support","works","device","access","kvm","latency","computer"].
Review highlights
Reviews
Best KVM in Smallest Size
"One of the best or perhaps the only one of its kind smallest online KVMs I’ve used recently! From the easy setup to the excellent build quality, long-term support, and continuous firmware updates from GL. iNet, this device has completely changed my perspective on what an online KVM can offer. One of the best features is the connection redundancy and failover support with Ethernet and Wi-Fi connectivity, giving you multiple ways to stay connected when you need remote access the most. Thanks, GL. iNet, for putting such powerful technology into our hands in such a simple and user-friendly way! Really impressive work."
Tahseen A. (5/5)
Agentic Control of PGX
"I got the Remote KVM for my Lenovo PGX in order to enable easier agentic control of the computer. The PGX is a work horse that I have on my network, but is not the computer I'm typically directly interacting with, it's more of an agentic middleware and 3D modeling tool. The infrastructure was working well, but sometimes the agentics would get blocked when cli was the only option, now with the KVM the agentic can fully control the PGX directly through the UI and it's doing exactly what I hoped it'd do!"
Michael Z. (5/5)
"Jeden z najlepszych KVM’ow jakie mialem - jesli ktos pracuje zdalnie lub uzywa wielu komputerow do pracy to polecam na 100% Bede pewnie kupował wiecej sztuk bo dziala to naprawde bezproblemowo. Na pewno zamowie tez nowa wersje ktora dziala po usb-c!!!"
Leszek (5/5)
This device works as it should & is supported well
"The device works great, across the Atlantic or from the pub :-) I had a small issue with the app that was hard to replicate, and support was extremely responsive and friendly; you are not left watching tumbleweeds pass by. I highly recommend this device not only for its functionality, but the team behind it."
Rob T. (5/5)
Great low-latency for remote gaming and work
"I am very satisfied with the Comet Pro so far. The latency is surprisingly low, and I can even play games at 2K 60 FPS with a smooth experience. The web client works really well and feels polished. The Windows app experience is also good. The iOS app still has some room for improvement compared with the Windows app, but overall the device is excellent for remote gaming while traveling, remote access, and even remote coding workflows. Overall, it is a very useful product and fits my use case very well."
Rocky (5/5)
It's working great but. . .
"I love how you implement EDID at the app level. I saw that you have the mouse jiggle implemented on the web interface, would love to see it in the mobile app as well! Otherwise love using this product!"
Guillermo R. (5/5)
Awesome terminal.
"The Terminal is easy to configure and connect to the system in the intended way."
Suresh Y. (5/5)
Awesome
"Just works"
Anatolii S. (5/5)
Top KVM
"easy to access"
Daniel K. (5/5)
"Excellent product"
A (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
