$175.99
Original price $175.99 - Original price $175.99
$175.99
Current price $175.99
MEET Spitz Plus
4G LTE Wi-Fi 6 Router
Cellular Connectivity Anywhere
GL-X2000 is a Wi-Fi 6 cellular router designed to provide stable cellular connectivity in remote locations and high-speed internet in urban areas. It features two external full-band LTE antennas for exceptional signal reception and supports dual SIM slots, ensuring redundancy to keep the device online at all times.
Supports 4G LTE CAT12 & Multi-WAN
Dual-SIM, Single Modem
Wi-Fi 6 Max. 574 Mbps (2.4GHz) + 2402 Mbps (5GHz) Wi-Fi Speeds
OpenVPN speed up to 30 Mbps; WireGuard speed up to 190 Mbps
Learn More Contact Sales Manager
Module: Quectel EG120K-NA
LTE LTE-FDD B2/ 4/ 5/ 7/ 12/ 13/ 14/ 25/ 26/ 29/ 30/ 66/ 71
LTE-TDD B41/ 48
UMTS WCDMA -
Regions North America
Module: Quectel EG120K-EA
LTE LTE-FDD B1/ 3/ 5/ 7/ 8/ 20/ 28/ 32
LTE-TDD B38/ 40/ 41
LAA -
UMTS WCDMA B1/ 3/ 5/ 8
Regions EMEA/APAC/Brazil
Qualcomm-powered
Mainboard & 4G Module
Wi-Fi 6 Technology
Dual Gigabit Ports
Dual SIM Flexibility
Interchangeable
External Antennas
30+ VPN Services
Fastest 4G
CAT12 Router
Multi-WAN Failover
Recreational Vehicles (RV) Deployment
Spitz Plus (GL-X2000) is a dependable cellular router for RVs, offering multiple WAN connectivity options through easy switching between the WAN port, SIM cards, and a Repeater. With four external antennas for enhanced connectivity, it can also connect to an extended wired dome antenna* for added stability in remote areas. For secure network access during travel, you can easily mount Spitz Plus on your RV's interior walls.
*Supports the use of external antennas that can be purchased separately and positioned outside the home for better signal reception.
Dual SIM
Dual SIM slots for redundancy to keep connected at all times
Fast Wi-Fi 6 connection
Fast Wi-Fi 6 connection for all the devices in the RVs
Secure network
Secure network when connecting to a public Wi-Fi
Seamless Internet Continuity for Your Home
The Spitz Plus (GL-X2000) is an essential router for any households, ensuring internet access with cellular connectivity when the ethernet network fails. With its Multi-WAN connectivity, you can seamlessly switch between WAN ports, SIM cards, and repeaters. For improved signal reception, the Spitz Plus can connect to external antennas on rooftops, providing extra stability in remote locations. This versatility makes it an ideal solution for maintaining dependable internet access, whether in urban, suburban, or rural settings.
Versatile Scenarios for Spitz Plus
RV Travel
RV Travel
Dual SIM cards to switch data services for your group in a snap.
Rural Areas
Rural Areas
Stable and long-range network connection using Multi-WAN & antennas in your sizeable country house.
Remote Work
Remote Work
Pre-installed Open VPN & WireGuard support 30+ VPN services, automatically encrypting all network traffic.
POS (Point of sale)
POS (Point of sale)
Bringing Robust Network Connections to Retail Stores.
Unparalleled Speed
Wi-Fi 6 Routers for 8K Streaming
Significantly enhanced speed allows for simultaneous streaming, rapid downloads, and seamless gaming. The 2.4GHz band achieves 574Mbps and the 5GHz band reaches an impressive 2402Mbps, ensuring smooth 8K video playback.
1167Mbps
4 Stream Wi-Fi 5
3000Mbps
Spitz Plus
250% Faster
160 MHz
Doubling bandwidth
CAT12
100% faster than CAT6
Compatible with the Best RV Antennas in the Industry
GL.iNet partnered with the industry's top RV antenna manufacturers to ensure seamless communication no matter where your journey takes you. Stay connected, stream, browse, and share memories on the road without interruption.
RV Use
Model: OmniRoam 4-in-1 Low-Profile Mobile Antenna (4G/5G & WiFi)
Learn More
Home Use
Model: MIMO 2x2 Panel External Antenna Kit
Learn More
Home Use
Model: DualMini Low-Profile 2x2 MIMO Window Antenna
Learn More
Stay Protected, Stay Connected
At GL.iNet, we prioritize your online security and privacy with advanced tools and features designed to protect your data, safeguard your family, and ensure a safe browsing experience across all your devices.
VPN Functionality
Spitz Plus is pre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. It automatically encrypts all network traffic within the connected network, including guest or client devices that are not capable of running VPN. Spitz Plus can also host VPN servers and supports VPN Cascading, automatically forwarding data from its VPN server to the VPN client within the same device.
OpenVPN speeds up to 30 Mbps
WireGuard® speeds up to 190 Mbps
X2000 30+ VPN service providers
AdGuard Home
Spitz Plus comes pre-installed with AdGuard Home, offering powerful ad-blocking capabilities to eliminate:
Popups, video ads, banners, and other intrusive ads.
Trackers and analytics systems that monitor your online activities.
Phishing attempts and malware attacks for a safer browsing experience.
AdGuard Home guarantees a clean and distraction-free web experience, protecting you and your family from harmful content.
X2000 AdGuard Home
AstroWarp
Spitz Plus comes with built-in AstroWarp, a powerful cloud-based networking platform that enables remote site-to-site networking, centralized device management, and future support for hardware-level control. Designed for users who need secure, scalable, and reliable network management, AstroWarp empowers both individuals and organizations to manage devices and maintain network stability with ease.
*The feature currently requires pairing with our beta firmware.
X2000's built-in AstroWarp
Easy Setup and Use
Our setup guide makes installing your new router a breeze! In just a few simple steps, you'll secure your device with an admin password, set up Wi-Fi to connect only trusted devices, and explore flexible network options like Ethernet, Repeater, Cellular and Tethering. Even if you’re new to tech, our intuitive process ensures a smooth start to your connected life.
Experience seamless connectivity with the Spitz Plus, fully compatible with GL.iNet's advanced eSIM solution, which support both physical eSIM cards and integrated eSIM chips*. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security.
※Integrated eSIM chip is available for bulk orders only.
Spitz Plus (GL-X2000) Reviews
  • Brilliant New E-Sim Campervan Router - GL.iNet Spitz Plus GL-X2000
  • Our New Caravan Internet Router And More, GL-iNet Puli AX, No More Messing About For Us!
  • Review: a week with the GL.iNet Spitz Plus (GL-X2000)
  • Portable Wi-Fi? Sign Me Up!
  • The RTX 5090 loses to a ROUTER!
  • 🙌 Huge thanks to @Bitwit for featuring the new Spitz Plus (GL-X2000)! 🚀
  • Cómo AUMENTAR LA VELOCIDAD DE INTERNET | Review GL.iNet GL-X2000 en español
  • Internet RURAL para Streaming REMOTO | GL.iNet Spitz Plus (GL-X2000) SIMPoYo SIM eSIM Physical Card
What Beta Tester are Saying
slide 10 to 12 of 8
Model Comparison
Spitz (GL-X750V2)
Spitz / GL-X750V2
4G LTE Smart Router
VS
Spitz Plus / GL-X2000
Qualcomm, @650MHz
CPU CPU
CPU CPU
Qualcomm Dual-core, @1GHz
DDR2 128MB / NOR Flash 16MB
DDR3L 512MB / Nand Flash 128MB
IEEE 802.11a/b/g/n/ac
Wireless Protocol Protocol
IEEE 802.11a/b/g/n/ac/ax
300Mbps(2.4GHz), 433Mbps(5GHz)
Wi-Fi Speed
Wi-Fi Speed
574Mbps(2.4GHz), 2402Mbps(5GHz)
2 x 10/100Mbps
Ethernet Speed Ethernet Speed
2 x 10/100/1000Mbps
1 x USB 2.0 port
USB Port
USB Port
1 x USB 2.0 port
1 x Micro SIM card slot
SIM Card Slot
SIM Card Slot
2 x Nano SIM card slot
12V
Product Input
Product Input
9V~36V
Max.10Mbps
OpenVPN (Via Ethernet)
Max.30Mbps
Max.38Mbps
WireGuard® (Via Ethernet)
Max.190Mbps
4G LTE CAT 12 Module
4G LTE
CAT12 Module
Wi-Fi 6
Wi-Fi 6
AX3000
Dual SIM
Dual SIM
Multi-WAN
Multi-WAN
OpenWrt Pre-installed
OpenWrt
Pre-installed
VPN Client/Server
VPN Client /
Server
AdGuard Home
AdGuard
Home
DFS
DFS
Specifications
1 x LAN Ethernet port
1 x USB 2.0 port
2 x Nano SIM card slots
1 x Reset button
CPU Qualcomm Dual-core, @1GHz
Memory / Storage DDR3L 512MB / NAND Flash 128MB
Protocol IEEE 802.11a/b/g/n/ac/ax
Wi-Fi Speed 574Mbps (2.4GHz), 2402Mbps (5GHz)
Antennas 2 x Cellular Antennas (SMA, 600M~3.8GHz)
2 x Wi-Fi Antennas (PR-SMA, 2.4G~2.5GHz, 5.15~5.84GHz)
LEDs Power / Internet / 2.4G Wi-Fi / 5G Wi-Fi / Cellular Signal Strength
Power Input DC5521, 12V/2.5A (5.5*2.1mm) [default adapter] / 9V~36V
Power Consumption <14W
Dimension / Weight 141 x 86 x 36mm / 443g
Looking for Bulk Purchase?
Contact Our Sales Manager
Frequently Asked Questions
Overall rating: 4.9512196 / 5 from 41 reviews.
AI Generated Review Summary
The Spitz Plus (GL-X2000) Wi-Fi 6 4G LTE CAT 12 Router offers stable cellular connectivity and high-speed internet with dual SIM slots and Wi-Fi 6 technology. It supports multiple connection methods and is compatible with top RV antennas, ensuring seamless communication. The device is praised for its performance and feature set, providing fast speeds and reliable connectivity.
Summary topics
  • Customer Service (16%): Customers keep praising the excellent customer service provided by the company, with fast responses and refunds.
  • Wi-Fi Speed (16%): The feedback is varied, but the Wi-Fi 6 is great, providing fast speeds for multiple devices.
  • Device Performance (16%): A significant number of customers raved about this device, praising its great performance and feature set.
Review topics: [quality, delivery, service, works, support, speed, connection, issues, setup, hardware, features, router, functionality, software, flexibility, device, performance, unit, internet, signal, storage, antennas, app, users, capabilities, vpn, network].
Review highlights
  • "The customer service was amazing, really fast reply’s and refund."Michael L.
  • "Very satisfied with unit and service provided."David C.
  • "Great VPN speeds but essential feature missing"AHMED A.
Reviews
Powerful quality + amazing service
"First the device : this thing is great quality in terms of soft and hardware. Packaging is neat, and from the moment I had it out of the box, and the moment I had it set up (with VPN client), I took about 30 mins. Second : customers' service is amazing. First order got lost during delivery and in a couple of weeks they shipped a replacement. It is a great thing to be able to reach the service without struggle, and be able to solve a problem that easily. So I won't doubt a second when ordering more hardware from Gl. inet."
Xi Y. (5/5)
Parfait
"Routeur un peu dur à paramétrer pour la carte sim mais matériel fonctionnant parfaitement. Semble solide et performant. Prix attrayant. Ce routeur vous change la vie en camping car. Seul bémol : pas de branchement 12v fourni avec le kit, cela oblige à couper le fil de l'adaptateur pour effectuer le branchement en 12v. Messieurs les fabricants, pensez donc à ceux qui se branchent en 12v. Merci"
didier C. (5/5)
Very satisfied
"This router is amazing. I will give 5 stars because the product is really good, but I am concerned about the firmware updates, which take a long time to be released."
Joao V. (5/5)
Great Support and Excellent Router
"GL. iNet handled a complicated shipping situation very professionally. Their customer service was responsive, helpful, and resolved the issue generously. The Spitz Plus (GL-X2000) is also a solid and reliable router. Very satisfied with both the product and the support."
Anton (5/5)
Very cool 4G LTE Router
"The newer Spitz Plus deserves its, since it has way more processing power and more onboard RAM and Flash storage. OpenWRT root privileges too :)"
Christian W. (5/5)
I'm really satisfied with my
"I'm really satisfied with my new router! Setup was straightforward, and now all my home devices are connected seamlessly. The network has been rock-solid and steady, with reliable 4G LTE performance. Highly recommended for anyone needing a dependable mobile internet solution."
Barry T. (5/5)
The 4G signal in Taiwan
"The 4G signal in Taiwan is quite good."
Yenmin C. (5/5)
Extremely Happy!
"I’m extremely happy with the GL. iNet Spitz Plus (GL-X2000). Shipping was impressively fast from their EU-based store to Cyprus, and the product arrived well-packaged and ready to go. Setup at my sailing boat was very straightforward. Activating and configuring an eSIM using Roamless Flex was quick and painless, even for someone who isn’t a networking expert. The GL. iNet app and the web-based router portal both feel modern, clean, and intuitive, making configuration and monitoring easy from day one. One of the standout aspects is the cloud service for remote access, which works reliably and makes managing the router from anywhere incredibly convenient. Also features like defining failover priorities (e. g. , 4G, Ethernet, or Wi-Fi) are well thought out and easy to configure, giving great flexibility and peace of mind for always-on connectivity. Overall, the Spitz Plus delivers excellent performance, strong software support, and thoughtful features in a compact device. It’s a great choice for anyone looking for a reliable 4G router with advanced capabilities and an easy user experience. Highly recommended!!!"
Marinos (5/5)
We have yet to use
"We have yet to use the router in anger, but its all set up and ready to go thanks to your excellent customer support and tech support."
Andy K. (5/5)
Amazing product.
"I'm extremely satisfied with this buy. Everything functions perfectly right out of the box. I really like how features like AdGuard Home, DDNS, and WireGuard server are quick and easy to set up. Extra thanks to the support team. I contacted them twice before making the purchase, and they responded to all of my questions in less than 24 hours."
Viktor (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
