$129.99
$129.99
Current price $129.99
Meet Beryl 7
BE3600 Dual-band Wi-Fi 7 Travel Router
GL.iNet's Fastest VPN Dual-band Wi-Fi 7 Travel Router
As a fully upgraded version of our Beryl AX, Beryl 7 is a compact dual-band Wi-Fi 7 travel router that delivers the fastest VPN speeds (up to 1,100 Mbps via WireGuard®) in GL.iNet's travel router lineup. With PD compatibility, it can be powered using a standard phone charger cable, which not only reduces the weight and clutter in your luggage, but also makes it much easier to keep your travel router powered up. Capable of supporting 120+ devices concurrently-all in a sleek, portable design built for life on the go.
Fast Wi-Fi speeds: Max. 688 Mbps (2.4 GHz) + 2,882 Mbps (5 GHz)
Robust VPN performance: Max. 1,100 Mbps on WireGuard® and Max. 1,000 Mbps on OpenVPN-DCO
Streamlined travel convenience: Universal USB-C charging compatibility
Versatile high-speed connectivity: Dual 2.5GbE ports and support for 120+ client devices
Wi-Fi 7
3600 Mbps
Dual 2.5G Ports
Boosted Wired Connections
Blazing-Fast VPN
Max. 1100 Mbps
PD Compatible
for True Mobility
USB 3.0
AdGuard Home
Multi-WAN Failover
OpenWrt-based SDK
Flexible Customization
How Does the Beryl 7 Fit Your Life?
Connect All Devices for the Price of One
Why pay a separate internet fee for every device? The Beryl 7 is your key to significant savings on the go. Simply connect it to the paid network once, and then share secure Wi-Fi with your phone, laptop, tablet, and more-all under a single access cost. Maximize your connectivity while you minimize your expenses and effortlessly bypass the captive portals with a one-time setup-no repeated logins required.
*Note: Travel routers may be prohibited by some cruise lines. Please check the specific regulations of your cruise line before use.
Stream Your Home Media, Anywhere
With Beryl 7, any hotel room can become your private theater. Connect to the hotel Wi-Fi, activate the built-in ultra-fast VPN client to access your home server, and plug in your streaming device or smart TV. Instantly, enjoy your personal media library and stream 8K content at high speed with complete privacy—as if you never left home.
File Sharing for Family Trips and Team Travel
Beryl 7 makes media and document sharing effortless during group travel. Connect an external USB drive to instantly create a private network storage space, supporting 120+ connected devices simultaneously. Family members or team members can securely access and share photos, videos, and work files—without relying on unstable public networks or limited cloud services. Everyone stays connected through a centralized, secure hub, making collaboration and memory-sharing seamless wherever you go.
Remote NAS Access & Backup on the Go
With Beryl 7 acting as a VPN client, you can securely connect back to your home network anytime, anywhere. Paired with the Brume 3 (GL-MT5000) at home, it enables seamless remote access to your NAS devices, letting you manage files, stream media, or even perform real-time photo backups directly to your home storage. This setup ensures your personal data remains private and protected over encrypted connections, while giving you LAN-like access as if you were physically at home.
Drop-Free Calls, Anywhere You Roam
For digital nomads, a reliable internet connection is essential. Beryl 7 can turn any location—a café, co-working space, or beachside apartment—into a secure, productive remote office. It ensures crystal-clear VoIP calls and stable video conferences, while a dedicated guest network keeps your main connection secure for client collaborations.
Secure Access to Your Internal Network
For business travelers, accessing company resources restricted to specific office IP addresses can be challenging. Beryl 7 solves this seamlessly. Pre-configured with OpenVPN and WireGuard, it can act as a VPN client to securely connect back to your office network, giving you access to internal systems, file servers, or managed printers—as if you were physically in the office—all over a fully encrypted connection.
Versatile Connectivity for Uninterrupted Access
Never settle for weak signals. Beyond multiple connection methods—including Ethernet, Wi-Fi repeating, and cellular tethering—Beryl 7 is truly smart. Its advanced Multi-WAN feature provides automatic failover, constantly monitoring networks and switching to the best available connection to prevent drops. This ensures a robust, private network with the consistent high performance needed for gaming, 8K streaming and other data-intensive tasks.
Transform Your Mobile Hotspots into a Powerful Home Network
Beryl 7 can turn your Mobile Hotspots or smartphone data plan into a high-performance Wi-Fi 7 network. Simply connect via USB and activate tethering mode, and it will receive the cellular signal and rebroadcast it as a superior Wi-Fi network throughout your space. With support for over 120 simultaneous connections, every device enjoys stable, high-speed internet—eliminating weak signals and connectivity limitations once and for all.
Unlock Global Content in Your Dorm Room
Beryl 7 lets you and your roommates bypass geographical restrictions simultaneously using a single VPN account. Supporting 30+ VPN service providers, this compact router provides seamless access to region-locked streaming services and video game platforms across all your devices. It also lets you apply VPN protection to the entire network or select specific devices, eliminating the need for individual per-device VPN subscriptions while ensuring everyone can enjoy their preferred content without compromise.
Encrypted Remote Access for Traveling Homelabbers and Media Lovers
For homelab enthusiasts and media collectors who travel, the Beryl 7 ensures your entire home network is always within reach. By establishing high-speed encrypted tunnels via WireGuard or OpenVPN, it provides seamless, secure access to your home servers, development environments, and personal media libraries from anywhere. This eliminates the risks of public internet exposure while delivering LAN-like responsiveness, letting you manage critical services or stream your movie collection as if you were locally connected.
Wire-free Control for Wired Devices
Beryl 7 enables seamless wireless control for Ethernet-only devices through a simple setup: connect the device to the router's LAN port and use your smartphone or tablet for wireless management. This compact solution is ideal for digital audio systems, mini-PCs, PLCs, and other equipment lacking native wireless capability. With flexible uplink options including Wi-Fi relay, Ethernet/USB tethering, plus built-in VPN support for secure data transmission, Beryl 7 provides a complete connectivity solution in a minimal footprint.
Beryl 7 (GL-MT3600BE) Reviews
  • BEST Travel Router!
    BEST Travel Router!
  • Gl.iNet Slate 7 PRO Travel Router Revealed
    The Newest Travel Routers...
  • Gl.iNet Beryl 7, Comet 5G and Flint 3e Revealed
What Beta Testers are Saying
The device worked stably both at home and during my vacation. At home, I connected it to my IoT network (40+ devices), and everything was stable.
@amuzyche
I love the Beryl 7 ... is the perfect mix of portability and power. Its slim design fits anywhere, while the performance ensures I stay securely connected to my home network—no matter where I am.
@halb_Tarif
I am a long-time user of GL.iNet devices, and ... they have never let me down, are incredibly easy to set up, and have proven to be an invaluable tool for both travel and everyday connectivity. Their latest addition, the Beryl 7, is an outstanding device that upholds GL.iNet’s tradition of providing reliable, and fault-free travel networking solutions.
@alex_591713
Repeating American Airlines inflight. Set up was super smooth.
@Randomstart
In summary, I found the product impressive. The build quality is strong, the colour choice gives it a modern feel, and its Wi-Fi 7 performance was comparable to the Slate 7 I tested recently. It stands out as a solid, more budget-friendly alternative to the Slate 7 for users who don’t require a display.
@mnavis29
I'm using mine at another job site onsite in an office. Connected right up to their guest WiFi with breeze and created my own private little network for my work laptop and phone. Been running smooth and haven't had anymore issues with Adguard. I was on the other side of the building with my laptop with multiple walls and brick in between and still getting some signal from it.
@Xdarkhawkx
As the predecessor, the Beryl and Beryl AX, for sure the newcomer is a great platform for frequent travelers with basic network knowledge as well as for OpenWrt enthusiasts.
@LupusE
Model Comparison
Beryl AX (GL-MT3000)
VS
Reliable Wi-Fi 6 for Basic Travel Needs
Positioning Positioning
High-value Wi-Fi 7 for Speed and Affordability
MediaTek, Dual-core @1.3GHz
CPU CPU
CPU CPU
MediaTek, Quad-core @2.0GHz
DDR4 512 MB / NAND Flash 256 MB
DDR4 512 MB / NAND Flash 512 MB
10/100/1000 Mbps
LAN Ethernet Speed LAN Ethernet Speed
100/1000/2500 Mbps
574 Mbps (2.4GHz), 2402 Mbps (5GHz)
Ethernet Speed Wi-Fi Speed
688 Mbps (2.4GHz), 2882 Mbps (5GHz)
Max. 300 Mbps
OpenVPN-DCO (Via Ethernet) OpenVPN-DCO
(Via Ethernet)
(Via Ethernet)
Max.1000 Mbps
Max. 300 Mbps
WireGuard® (Via Ethernet) WireGuard® (Via Ethernet)
Max.1100 Mbps
Type-C, 5V/3A
Power Input Power Input
Type-C, 5V/3A, 9V/3A, 12V/2.5A
120 x 83 x 34mm / 196g
Dimension / Weight Dimension / Weight
120 x 83 x 34mm / 205g
OpenWrt Pre-installed
OpenWrt
Pre-installed
Tri-band Wi-Fi 7
Wi-Fi 7
VPN Client / Server
VPN Client /
Server
2.5G Ethernet Ports
Dual 2.5G
Ethernet Ports
USB 3.0 Port
USB 3.0 Port
Multi-Link Operation
Multi-Link
Operation
Partenal Controls
PD Power Supply
(5V/3A, 9V/3A, 12V/2.5A)
Partenal Controls
DNS Encryption
Technical Specifications
1 x LAN Ethernet port
1 x USB 3.0 port
1 x Type-C Power port
1 x Reset button
1 x Toggle button
Memory / Storage DDR4 512MB / NAND Flash 512MB
Wi-Fi Speed 688Mbps (2.4GHz), 2882Mbps (5GHz)
Antennas 2 x foldable external Wi-Fi antennas
Power Input Type-C, 5V/3A, 9V/3A, 12V/2.5A
Power Consumption <12W (without USB)
Dimension / Weight 120 x 83 x 34mm / 205g
Frequently Asked Questions
Overall rating: 5.0 / 5 from 21 reviews.
AI Generated Review Summary
Summary topics
Review topics: ["size","delivery","speed","works","performance","interface","features","router","hardware","setup","device","server","travel","configuration"].
Review highlights
Reviews
Good performance work prefect with Brume3
"I’ve been using the GL-MT3600BE as my main router and overall I’m very happy with it. The setup was straightforward, and the performance has been stable even with multiple devices connected at the same time. The hardware feels solid and the interface is relatively easy to use. I especially like the flexibility for advanced network configurations, including VPN and Tailscale-related features. Wi-Fi performance has also been reliable around the house. One thing I would improve is the documentation. Some of the more advanced settings can take a bit of trial and error to understand, especially if you’re setting up things like subnet routing or more complicated network configurations. Overall, it’s a powerful and flexible router, particularly for users who want more control over their network than a typical consumer router provides. Definitely recommended for advanced home users."
Bowen J. (5/5)
Great router for vpns
"Great router for Home and travel use I use this as a private wifi with a vpn for me in my room and a WiFi extender because the main router is in the corner of the house the only bottlenecks was that I used power line and a vpn that’s far away it was still 200mbps even with those caveats. It is also very simple so I made a 3d printed wall mount for it"
Anthony (5/5)
Surprising Success So Far
"Was easy to set up, no issues connecting or being used as advertised/intended. Does indeed power off 5W."
Stephen B. (5/5)
"It's really tiny and compact, and comes with all the necessary plug connectors"
孙裔 (5/5)
Very good product
"I am very happy with my purchase. Everything works well. Fabulous quality!"
Florian R. (5/5)
Great priduct, quick delivery
"I use this router in repeater mode with a VPN fusion enabled. It gives me 3x higher download speed than Asus router with VPN fusion that I was using before. Same internet provider, same VPN server/service. Great versatile product. Looking forward to official 4. 9. firmware with full amnezia wg 2. 0 support. Delivery to Slovakia was super quick! Shipment came from Germany in just 3 days from ordering."
Milan Z. (5/5)
High-quality and reliable device
"This device does its job perfectly. The internet speed is great, and the user interface is intuitive and easy to navigate. It met all my expectations and offers excellent value for the money. 5 stars!"
Julius S. (5/5)
Highly configurable, portable, great UI.
"Highly recommended as a travel necessity."
Rozalia G. (5/5)
Very good product
"The router with good function, very helpful."
Mon C. (5/5)
Both great
"The travel one gets hot fast but they both work as expected and easy to setup"
Heberth H. (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
