$98.99
Original price $0.00 - Original price $0.00
$98.99
Current price $98.99
MEET Beryl AX
A Pocket-sized Wi-Fi 6 Router for Home and Travel
Pocket-sized AX3000 VPN Router for Network Security
Beryl AX (GL-MT3000) is an AX3000 pocket-sized travel router that uses the Wi-Fi 6 protocol. It is an upgraded version of Beryl (GL-MT1300), it runs on MT7981B 1.3GHz dual-core processor, offering more than double the total Wi-Fi speed compared to previous generations. It is designed to support families with heavy Wi-Fi usage, and it's also compactly designed for travel use.
Max. 574 Mbps (2.4GHz) + 2402 Mbps (5GHz) Fast Wi-Fi Speeds
OpenVPN speed up to 150 Mbps; WireGuard® speed up to 300 Mbps
2.5G Multi-gigabit WAN port
Learn More View Online Guide
An Exceptional Wi-Fi 6 Experience
Wi-Fi 6's is a powerful upgrade in mass device connectivity and OFDMA data transmission efficiency technologies. On top of this, Wi-Fi 6 comes with a series of internet technology breakthroughs, including Beamforming for enhanced coverage and BSS Coloring for minimal network congestion.
Beryl AX (GL-MT3000) is pre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. It automatically encrypts all network traffic within the connected network, including guest or client devices that are not capable of running VPN. Beryl AX can also host VPN servers and supports VPN Cascading, automatically forwarding data from its VPN server to the VPN client within the same device.
WireGuard
Max. 300Mbps
OpenVPN
Max. 150Mbps
70+ Devices Mass Device Connectivity
Wi-Fi 6's is a powerful upgrade in mass device connectivity and OFDMA data transmission efficiency technologies, letting Beryl AX connect with 70+ devices simultaneously. On top of this, Wi-Fi 6 comes with a series of internet technology breakthroughs, including Beamforming for enhanced coverage and BSS Coloring for minimal network congestion.
Smaller than your palm
An Engineering Masterpiece
Beryl AX comes with a 2.5G Multi-gigabit WAN port and a 1G gigabit LAN port, it is capable of processing network and VPN packets efficiently using its MediaTek MT7981B 1.3GHz Dual-core processor. The router also comes with a Type-C power supply and a USB 3.0 port for external storage.
Beryl AX's latest SDK4.0+ firmware presents a user-friendly interface for common users to set up the router with minimal inputs, and an extended customization experience for advanced users to install plug-ins and applications. Beryl AX runs on open source OpenWrt 21.02 (Kernel version 5.4) firmware, supporting more than 5,000 ready-made plug-ins for customization. Simply browse, install, and manage packages with our no-code interface within Beryl AX's Admin Panel.
Access Your Local Network Storage
Our local network storage feature supports SAMBA and WebDav protocol. By plugging an external USB hard disc into the router, you can create a private network to store and share your documents. No matter for work or family, you can benefit from easy file access. Save space on your devices by storing photos and videos on the network.
DFS Certification in US, UK, Europe & Japan
Beryl AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications. The selection of additional channels can lower network congestion under high density network environments.
WPA3 protocol
WPA3 protocol
DNS over HTTPS & DNS over TLS
AdGuard Home
AdGuard Home
IPv6
IPv6
Use Beryl AX together with the GL-M2 Development Board which is designed to connect you to a 5G network and give you the internet you deserve. With a built-in SIM card slot, the GL-M2 Development Board serves as a 5G modem for your router to get your internet up and running, whether you are residing in a remote area with no internet access or traveling on the road. Even better, the GL-M2 Development Board features multi-WAN, supporting failover and load balancing to keep you connected at all times.
Model Comparison
Opal (GL-SFT1200)
Opal
(GL-SFT1200)
Gigabit Wireless Router
Slate Plus (GL-A1300)
Slate Plus
(GL-A1300)
Gigabit Travel Router
Beryl (GL-MT1300)
Beryl
(GL-MT1300)
Beryl AX
(GL-MT3000)
Wi-Fi 6 Travel Router
CPU SF19A28, Dual-Core @1GHz IPQ4018, Quad Core@717MHz MT7621A @880MHz MT7981B Dual-core@1.3GHz
RAM DDR3 128MB DDR3L 256MB DDR3L 256MB DDR4 512MB
FLASH SPI NAND Flash 128MB NOR Flash 4MB + NAND Flash 128MB NOR Flash 32MB NAND Flash 256MB
Gigabit Port 2.5G
Wi-Fi Speed 300Mbps(2.4GHz),
867Mbps (5GHz)
400Mbps (2.4GHz),
867Mbps (5GHz)
400Mbps (2.4GHz),
867Mbps (5GHz)
574Mbps (2.4GHz),
2402Mbps (5GHz)
MicroSD Slot
USB Port USB 2.0 USB 3.0 USB 3.0 USB 3.0
OpenVPN
(Via Ethernet)
Max. 21Mbps Max. 28Mbps Max. 21Mbps Max. 150Mbps
WireGuard®
(Via Ethernet)
Max. 65Mbps Max. 170Mbps Max. 91Mbps Max. 300Mbps
Beryl AX (GL-MT3000) Reviews
  • Video 2
    I didn’t know I needed this - GL.iNet Beryl AX
  • Video 3
    WiFi 6 Travel Router with Wireguard & OpenVPN : GLI.Net BERYL AX3000
  • Video 4
    Neues von GL.iNET Brume 2 & Beryl AX // Man in the Middle Attack
  • Video 4
    [Unboxing] Beryl AX Wi-Fi 6 Router (Model GL-MT3000)
  • Video 4
    Travel with WiFi 6 - GL-iNet Beryl GL-MT3000 WiFi 6 Travel Router Review
  • Video 4
    GL-iNet Beryl AX WiFi6 AX3000 Travel Router Overview & Speedtest (GL-MT3000)
  • Video 4
    O MINI ROUTER que é MELHOR que o Router da OPERADORA! (VPN, Adguard, TOR) | BERYL AX (GL-MT3000)
  • Video 4
    Beryl AX GL-MT3000 Wi-Fi 6 & 2.5G Travel Router Review - INSANE $99 Router?
  • Video 4
    Beryl AX3000 Router Review | Fastest Router I've Ever Used! Up to 500+ Mbps on Wi-Fi 6!!!
  • Video 4
    Beryl AX Review en ESPAÑOL | El mini router VPN más POTENTE del mercado
  • Video 4
    Tiny Router Showdown - 2.5G, Tethering, and Docker?
  • Video 4
    GL iNet Beryl AX-Faster, More Compact, & 70+ Wireless Clients
  • Video 4
  • Video 4
    Travel Routers Improve Your Life! Beryl AX Complete Setup
  • Video 1
    They just keep getting better - VPN routers on the go // GL iNet Beryl AX Review
  • Video 1
    Nejzajímavější produkty roku 2023.
  • Video 1
    Wireless Charging That Doesn’t Suck - Qi 2
  • Video 1
    GL.iNet GL-MT3000 and GL-AXT1800 Wi-Fi 6 Travel Routers
  • Video 1
    GL.iNET Travel Router Comparison - Beryl AX (GL-MT3000) vs Opal (GL-SFT1200)
  • Video 1
    Which GL.iNet travel router is best for you?
  • Video 1
    Using a GL.iNet travel router during a 3-week road trip
  • Video 1
    Take your WiFi with you! GL.iNet Beryl AX & Spitz AX
  • Video 1
    GL.iNet Beryl AX Super Small Travel Router
  • Video 1
    🔴 Extreme Rural Internet - 4G/5G Modems pull signal from Miles away #starlink #ruralinternet
  • Video 1
    Convert Your Starlink To 12-Volt DC // Complete Tutorial
  • Video 1
    SAFE and SECURE Travel WiFi: Don't Leave Home Without It!
  • Video 1
    TRAVEL ROUTER OR MOBILE HOTSPOT? - WHICH ONE IS BETTER FOR TRAVEL?
Wi-Fi 6
Wi-Fi 6
2.5-Gigabit Multi-Gig port
2.5G
Multi-Gig port
VPN Client/Server
VPN Client /
Server
USB 3.0 Port
USB 3.0
Port
OpenWrt Pre-installed
OpenWrt
Pre-installed
AdGuard Home
AdGuard
Home
DFS
DFS
Network
Storage
Specifications
1 x LAN Ethernet port
1 x USB 3.0 port
1 x Type-C Power Input
1 x Reset button
1 x Toggle button
CPU MT7981B Dual-core Processor @1.3GHz
Memory / Storage DDR4 512MB / NAND Flash 256MB
Protocol IEEE 802.11a/b/g/n/ac/ax
Wi-Fi Speed 574Mbps (2.4GHz), 2402Mbps (5GHz)
Antennas 2 x retractable external Wi-Fi antennas
Ethernet Speed WAN Port: 10/100/1000/2500Mbps
LAN Port: 10/100/1000 Mbps
Power Input Type-C, 5V/3A
Power Consumption <8W
Dimension / Weight 120 x 83 x 34mm / 196g
Looking for Bulk Purchase?
Connect with our team for volume pricing. Boost your business with GL.iNet’s advanced networking solutions.
  • Customizable and OpenWrt-based
  • Remote Device Management
  • White Label Service
  • Global Product Certifications
  • Self-owned Factory
Contact Our Sales Manager Become a Distributor
Frequently Asked Questions
Overall rating: 4.927746 / 5 from 346 reviews.
AI Generated Review Summary
The Beryl AX (GL-MT3000) is a pocket-sized Wi-Fi 6 travel router offering fast speeds, robust security features, and a user-friendly interface. It supports multiple devices, provides efficient VPN processing, and ensures secure connections with WPA3 and DNS over HTTPS. Ideal for both home and travel use, it offers a seamless experience for streaming, gaming, and secure browsing.
Summary topics
  • Device Performance (12%): Customers loved the device, praising its performance, ease of use, and port forwarding capabilities.
  • User Interface (5%): It was observed by customers that the interface of the product is clear, intuitive, and well-built.
  • Security Features (7%): It was highlighted by customers that the Beryl AX has a great security and convenience feature.
  • Wi-Fi Speed (10%): Customers appreciated the excellent speed and reliability of the router, making it perfect for streaming and gaming.
  • Connection Stability (8%): Customers raved about the connection, stating it consistently provides a stable and fast connection in airports and hotels.
Review topics: ["fit","size","quality","feels","package","value","delivery","works","service","speed","support","price","connection","performance","features","issues","setup","interface","wifi","use","software","hardware","functionality","router","design","tech","installation","device","reliability","advantage"].
Review highlights
  • "Setup is the easiest and the most straightforward, performance is good enough, size is amazing."Yan K.
  • "Speeds are holding well and the service is great."Francis G.
  • "The setup was super quick and easy, and the user-friendly interface made it simple to get everything running smoothly."Peter
Reviews
Perfect 5G USB Tethering Setup for the RV
"I’ve been using the Beryl AX (GL-MT3000) in my RV, and it has been an exceptional addition to my mobile network setup. I run it in USB tethering mode connected directly to my Samsung Galaxy S26 Ultra to capture the 5G signal, and the router effortlessly broadcasts high-speed internet throughout the entire RV. The setup process was straightforward, and the Wi-Fi 6 coverage is strong and consistent, ensuring all my devices stay reliably connected on the road. The compact form factor is perfect for the space constraints of an RV without compromising on performance or bandwidth. Highly recommended for anyone needing a dependable mobile internet solution."
SELIM (5/5)
Can’t make it work AT ALL.
"Ive spent HOURS and HOURS following MANY instructions from the website and other recommendations. I cannot get the Tether feature to connect. SOMETHING is preventing the iPhone to tether, NO internet connection …it was recommended that I set up the Beryl AX BEFORE I travel. No luck. Totally exhausting."
Lise C. (5/5)
Has every feature I need!
"It has all the functions I need and works seamlessly. I feel so much more confident accessing online banking while connected to public networks"
Gary L. (5/5)
Works like a charm
"A college recommended this device. The setup is really easy. You can connect all you devices at home. When you get to your travel destination, with a few clicks the router is connected to the wifi of tou destination and all your devices are automatically connected. It also pretty fast. I connected it to a 500mbit wifi network. The speedtest directly on the network was just a fraction slower then after the router. I love this thing!"
Olivier R. (5/5)
Super product
"This product changed my life I can freely browse the internet without having to be speid on, use my phone to create wifi and run it in my backpack with a powerbank"
ben (5/5)
Neat little travel router
"This has been excellent little addition to our travels, meaning my family can all connect to a single wifi access point wherever we go on our hols, whilst still being protected by our VPN and accessing our home network,"
Ash (4/5)
Top product
"Easy to use, lots of features. Small, easy to carry. I am very happy with it. I will buy a second one soon."
Steve W. (5/5)
Great for travel
"I use it to boost the public wifi from the hall of my hotel to my room as the walls tend to block a lot of the signal. It has been fantastic for this as I set it up behind the door of the room and get great service from it. I've had far fewer dropped signal errors with my work since I got it."
Thomas W. (5/5)
Very Capable Travel Router
"This router allows you to create your own private LAN connected to another network via Ethernet, WiFi, tether, or cellular. You'll have to supply your own cellular connector if that's the way you want to go. The embedded VPN allows you to keep your traffic safeguarded. It also allows you to handle port capture authentication through the router so connected devices just share the authenticated connection."
John B. (5/5)
Amazing travel router
"Bought the Beryl AX for travelling, haven't actually used it yet, only tested it, but it's amazing. The configuration is amazing, having the toggle on the side set to toggle connection to my WireGuard VPN is great. For my usage, there are no cons to this router."
Matej Č. (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
