$139.99
Original price $139.99 - Original price $169.99
$139.99 - $169.99
Current price $139.99
GL-E750V2
MUDI V2
Best Portable Wi-Fi Travel Router in 2024
CES 2020 Innovation Awards HONOREE
in the Cybersecurity and Personal Privacy product category
Portable 4G LTE Router
Mudi V2 by GL.iNet, is the best portable 4G LTE privacy router for road warriors and business travelers who want to secure their data and protect them from cyber criminals. With WireGuard® and OpenVPN settings, Mudi V2 gives the privacy-minded users a fast and simple VPN that utilizes state-of-the-art cryptography.
Supports 4G LTE, global carriers
Features VPN
Pocket-friendly
Supports failover, load balancing
Can last 8 hours per charge
Learn More View Online Guide
Pocket Wi-Fi on the go
Mudi V2 gives you a private bubble of internet wherever you go, with the added peace of mind that comes from knowing your online traffic is always protected by the VPN. With its support for global carriers, rest assured Mudi V2 works wherever the road takes you.
Runs on OpenWrt for Customization
A travel router that runs OpenWrt natively, Mudi V2 gives you full control of your network and the connected devices. Mudi V2 uses proprietary firmware based on OpenWrt (v22.03.4 Kernel version 5.150.176), offering over 5,000 ready-made plug-ins and applications at your disposal. Simply browse, install, and manage packages within the router's admin panel.
Best Travel Router with VPN
Protect your data with integrated VPN Client
Mudi V2 offers built-in VPN functionality to help you stay private and secure at all times. With its support for OpenVPN or WireGuard, the travel router protects your online traffic anywhere you go. All you need to do is get a VPN subscription from one of the over 30 VPN service providers supported by GL.iNet.
Built-in with VPN server for remote access
Mudi V2 supports running as a VPN server, allowing you to securely access your home or office network from anywhere in the world. The router supports running as a VPN client and a VPN server at the same time, meeting your needs all at once.
WireGuard
Max. 40Mbps
OpenVPN
Max. 5Mbps
Improved Network Reliability with Multi-WAN
Mudi V2 offers four connection methods—cellular, tethering, Wi-Fi, and ethernet. Featuring multi-WAN, the travel router supports failover and load balancing, ensuring uninterrupted internet connectivity wherever you go.
Cafe
Coffee shops
Whether you’re working from a cafe or just stopping by for a coffee, use Mudi V2 to establish a private internet connection and stay away from prying eyes.
Office
Hotel rooms
Hotel Wi-Fi is not always safe. Use Mudi V2 for a private, secure connection. Also, you can save on excessive Wi-Fi fees and avoid poor internet service.
On-the-Go
On the road
Mudi V2 meets whatever your needs are while on the road—letting you watch your favorite content, live stream, or access a network remotely.
Experience seamless connectivity with the Mudi V2, fully compatible with GL.iNet’s advanced eSIM solution, which supports both physical eSIM cards and integrated eSIM chips*. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security. For consumers, this means effortlessly switching networks and avoiding roaming charges, while businesses benefit from centralized management, multi-device support, and secure data management.
*The feature currently requires pairing a physical eSIM card with our firmware. Integrated eSIM chip is available for bulk orders only.
Become Our Value-Added Distributor
Grow your business with our products and very own cloud management platform, GoodCloud, which is customizable with your business logo and style. GoodCloud features role management settings and beyond—making device management faster and simpler.
Apply Now
Module: EM060K-G
LTE LTE-FDD B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B17/B18/B19/B20/B25/B26/B28/B29②/B30/B32①/B66/B71
LTE-TDD B34/B38/B39/B40/B41/B42/B43/B46① (LAA)/B48 (CBRS)
Up to 2 ×CA: B2+B2/5/12/13/29③;B4+B4/5/12/13/29③; B5+B5/7/25/30/66; B7+B7/12/26;B12+B12/25/30/66; B13+B66; B25+B25/26; B30+B29; B66+B29/66; B41+B41;
WCDMA: B1/2/3/4/5/6/8/19
①: B32 is only for secondary component carrier, B46 is only for secondary component carrier.
②: B29 is only for secondary component carrier.
③: means LTE-FDD B29 support receiving only, and is only for secondary component carrier in 2×CA.
Module: EM05-G
LTE B1/2/3/4/5/7/8/12/13/14/18/19/20/25/26/28/66/71/38/39/40/41;
WCDMA B1/2/4/5/6/8/19
Mudi V2 (GL-E750V2) Reviews
  • Video 0
    INTERNET ANÓNIMA MÓVEL E SEGURA EM QUALQUER LADO! | MINI ROUTER MUDI V2 4G LTE (GL-E750V2)
  • Video 1
    SHEIN è convenientissimo!
  • Video 2
    MUDI V2 Travel Router Review - This Router Is FAST!
  • Video 3
    GL-iNet mudi Portable 4G LTE Router GL-E750V2 Review
  • Video 4
    Mudi: Il Router Portatile 4G Che Rivoluzionerà il Tuo Modo di Connetterti!
  • Video 5
    GL-iNet Mudi V2 - Portable 4G LTE Router - Unbox & Review
  • Video 6
    How-To Setup Gl.iNet Mudi 4G LTE Wireless Travel Router Review
  • Video 7
    Le passeport pour un WiFi sans frontières : l’outil INDISPENSABLE des voyageurs connectés ? MUDI V2
    4G LTE Module
    4G LTE
    Module
    High Speed
    High Speed
    Dual-band Wi-Fi
    Dual-band
    Wi-Fi
    External Storage
    External
    Storage
    External Storage
    Built-in
    Battery
    VPN Client/Server
    VPN Client /
    Server
    Tor
    Tor Anonymity
    OpenWrt Pre-installed
    OpenWrt
    Pre-installed
    Global Connectivity
    Global
    Connectivity
    DNS Encryption
    DNS
    Encryption
    Specifications
    Interface 1 x USB 2.0 port
    1 x Nano SIM card slot
    1 x MicroSD card slot (Up to 1TB)
    1 x Toggle button
    1 x Power button
    CPU QCA9531, @650MHz SoC
    Memory / Storage DDR2 128MB / NOR Flash 16MB + NAND Flash 128MB
    3G/4G Modem CAT4 Module (DL/UL 150/50Mbps) or CAT6 Module (DL/UL 300/50Mbps)
    LTE Antenna 2 x Internal Full Frequency Antennas (700M~2.7GHz)
    Protocol IEEE 802.11a/b/g/n/ac
    Wi-Fi Speed 300Mbps (2.4GHz), 433Mbps (5GHz)
    Ethernet Port 1 x FE Port (supported with the docking station)
    LED 0.96-inch OLED Display
    Power Input Type-C, 5V/2A
    Battery Rechargeable 7000mAh Battery
    Operating Temperature 0~35°C (32~95°F)
    Storage Temperature -20~45°C (-4~113°F)
    Dimension / Weight 145 x 77.5 x 23.5mm / 285g
    Looking for Bulk Purchase?
    Contact Our Sales Manager
    Frequently Asked Questions
    Overall rating: 4.740741 / 5 from 54 reviews.
    AI Generated Review Summary
    The Mudi V2 Portable 4G LTE Router offers fast and reliable internet speeds, is highly regarded as the best mobile hotspot device, and has mixed reviews on support. It provides a secure VPN connection and supports multiple global carriers.
    Summary topics
    • Internet Speed (18%): Based on a significant number of customers, the general consensus is that the product provides fast and reliable speeds.
    • Device Quality (25%): A significant number of customers brought up that this device is great and the best mobile hotspot device they have used.
    Review topics: ["size","speed","support","works","battery","setup","interface","looks","issues","device","router","capabilities","space"].
    Review highlights
    • "Great support team and great device"Yugo N.
    • "Perfect size, great speed, easy setup."Eric L.
    • "Good travel router would like 5G support"Bruce
    Reviews
    Top
    "Thx for service 👌"
    Charles G. (5/5)
    Excellent Travel Router for the Price
    "Excellent travel router, its size and weight is great for using while travelling. I have had no issues with connectivity, it connects to a network straight away, and its easy and quick to set up a VPN. The Dashboard is easy yo navigate and understand, the dashboard gives you further settings and control over the router. I highly recommend this router and its price."
    Rob (5/5)
    Awesome! Congrats!
    "The device is unbelievable outstanding! Perfect job! Congrats! ;) I can't wait for the V3 :). Capacity of battery is absolutely sufficent. One of the best purchasing selection I've made ;D."
    Krystian W. (5/5)
    Recently purchased because I had
    "Recently purchased because I had a trip coming up to the Philippines and I ve been using it out here and works great!!! Highly recommended!! Waiting for the new Mudi to come out!!!"
    Mauro R. (5/5)
    Performs as expected although there
    "Performs as expected although there are niggles with the SMS text messaging interface -- needed for now as my 4G LTE network provider manages billing this way on PAYG -- it can't view messages bigger than 160 characters in the GL-inet vendor web UI. The workaround is to SSH in and view them from the root shell in /etc/spool/sms/incoming. Upgrading to the 4. 8 beta firmware to address this caused a bunch of issues and the rollback to 4. 3 as shipped was not entirely clean."
    B S. (5/5)
    Must have Product!
    "This was my first Gl. Inet device ever and I couldn't be more happy with how it works!! Zero issues, easy to upgrade with both OTA & Manual way and also super easy configuration. the inbuilt VPN capabilities are the cherry on top of this device. Worked flawlessly with all carriers I've tried so far. Plus I'm absolutely in love with Toggle button actions 100% recommended!!"
    GioKas93 (5/5)
    Perfect for anyone
    "Setup: Super simple. The GLiNet GUI is clean, friendly, and perfect for everyday users. No tech headaches here. Battery: Long-lasting. It keeps going through workdays and travel without begging for a charger (intensive use, lasted for 2 days; this might depend) Speed: Solid performance. Unless the weather or signal's acting up, your data flows fast and smooth. The OpenWRT implementation turns this into a wireless sandbox, VPNs, custom configs, playing with guest network firewalls, almost everything. Reliability: Zero issues so far. It's stable, dependable, and quietly brilliant. (The boot time and sim card connection procedure takes around 7 minutes, I recommend keeping this in "Standby Mode" when you don't use it so you won't have to wait too much)"
    Florence (5/5)
    Hands down the best products!
    "This is by far the best mobile hotspot device I have used. Perfect size, great speed, easy setup. Paired it with the GLiNet / SIMPoYo 5G/4G plan. Hands down the best setup. So much time wasted on others plans and devices when I should've just used GLiNet in the first place. Don't question it, just buy it. You'll thank me later!"
    Eric L. (5/5)
    The device is compact. Finding
    "The device is compact. Finding the cover over the sim card is a little tricky the first time. Speed looks good and i will know more about the battery. soon. Very easy to set up. Overall the unit looks great."
    X S. (5/5)
    The best portable router with
    "The best portable router with 4 different internet inputs, 2 WiFi bands, with all types VPN. Easy management for user and profi. Hi speeds!"
    Tovmas S. (5/5)
    Q&A
    • Free Local Shipping
      Fast delivery
    • Rewards on Every Order
      2 points for every $1 spent
    • 2-Year Warranty
      Reliable product coverage
    • 30-Day Returns
      Fast and easy refunds
