The Pocket-Sized Router for Smarter Travel
Mango 2 (GL-MG1300) is a compact travel router designed to keep your devices connected without adding bulk to your journey. Connect it to hotel Wi-Fi, Ethernet or your phone’s mobile data, then bring your laptop, phone and tablet onto one familiar travel Wi-Fi. With USB-C power and built-in VPN support, Mango 2 keeps everyday travel networking simple and easy to carry.
Pocket-Sized & Lightweight: 89*63*15 mm / 100g
Dual-Band Wi-Fi: Up to 400 Mbps (2.4 GHz) + 866 Mbps (5 GHz)
VPN Performance: Up to 184 Mbps with WireGuard® and 95 Mbps with OpenVPN DCO
Advanced Network Management: GoodPAS, Tailscale, and Multi-Tunnel VPN
Mango 2 (GL-MG1300) Reviews
The UniFi Travel Router Killer? The Gl.iNet Mango 2 Travel Router Revealed
The Little Yellow Router, Reimagined
Mango |
VS |
Mango 2 |
| MediaTek, Single-core@580 MHz | CPU | MediaTek, Dual-core@880 MHz |
| Max. 300 Mbps | 2.4 GHz Wi-Fi Speed | Max. 400 Mbps |
| 5 GHz Wi-Fi Speed | Max. 866 Mbps | |
| Max. 45 Mbps | WireGuard® Performance | Max. 184 Mbps |
| Max. 11 Mbps | OpenVPN Performance | Max. 95 Mbps (with DCO) |
| 10/100 Mbps | Ethernet Speed | 10/100/1000 Mbps |
| USB 2.0 port | USB Port | USB 3.0 port |
| Micro‑USB, 5V/2A | Power Input | USB‑C, 5V/2A |
Mango
Mango 2
CPU
MediaTek, Single-core@580MHz
CPU
MediaTek, Dual-core@880MHz
2.4 GHz Wi-Fi Speed
Max. 300 Mbps
2.4 GHz Wi-Fi Speed
Max. 400 Mbps
5 GHz Wi-Fi Speed
5 GHz Wi-Fi Speed
Max. 866 Mbps
Max. 45 Mbps
Max. 184 Mbps
OpenVPN Performance
Max. 11 Mbps
OpenVPN Performance
Ethernet Speed
10/100 Mbps
Ethernet Speed
10/100/1000 Mbps
USB Port
USB 2.0 port
USB Port
USB 3.0 port
Power Input
Micro‑USB, 5V/2A
Power Input
USB‑C, 5V/2A
Specifications
| Interface |
1 x WAN Ethernet Port 1 x LAN Ethernet Port 1 x USB 3.0 Port 1 x Type-C Power Port 1 x Reset Button 1 x Toggle Button |
| CPU | MediaTek, Dual-core @880 MHz |
| Memory / Storage | DDR3L 128 MB / NOR 2 MB + NAND 128 MB |
| Protocol | IEEE 802.11a/b/g/n/ac |
| Wi-Fi Speed | 400 Mbps (2.4 GHz) , 866 Mbps (5 GHz) |
| Internal Antenna | 2 × 2.4 GHz & 5 GHz |
| Power Input | Type-C, 5V/2A |
| Power Consumption | <5W |
| Operating Temperature | 0°C ~ 40°C (32°F ~ 104°F) |
| Dimension / Weight | 89*63*15 mm / 100g |
