$99.99
Original price $99.99 - Original price $99.99
$99.99
Current price $99.99
MEET Comet
Remote KVM over Internet
What is Remote KVM?
Remote KVM (Keyboard, Video, Mouse) is a device that lets you control a computer or server from anywhere, as if you were sitting right in front of it. Imagine you're traveling, but you need to access and fix a computer at your office. With a Remote KVM, you can see the screen, use the keyboard, and move the mouse just like you were physically there.
It's commonly used by IT professionals, businesses, and data centers to troubleshoot, manage, and maintain computers remotely without needing to be on-site.
Applications of Remote KVM for home and office use, remote controlling office computer at home using GLKVM application
Why Choose Comet?
One-time purchase - No subscription fees, ever
4K@30FPS video with H.264 hardware encoding for smooth performance
Remote file transfer - Even for offline devices
Ultra-low latency (30ms-60ms) for real-time remote control
USB-Device port for power control accessories or USB drives
Gigabit Ethernet for high-speed, stable connections
Type-C power supply for hassle-free setup
Remote Audio Output for immersive and complete remote control
8GB eMMC Storage
Two-way Audio
Browser-Based Access
4K@30FPS Video
Tailscale Support
BIOS Access
Self-Hosted Option
Home computer with Comet, remote KVM, for remote work, running video editing software.
Laptop remotely accessing home computer via Comet KVM for seamless video editing.
Work computer connected to Comet KVM for remote access, displaying late-night coding session.
Remote developer using laptop to control work computer via Comet KVM switch.
Home office setup with Comet KVM switch, laptop, and router for secure remote work.
Remote laptop access with Comet KVM, showing consistent workflow between devices.
Work Smarter from Home
Struggling with IT restrictions on your company laptop? Traditional KVM switches can be slow and disruptive, but Comet offers a smarter solution.
It allows remote workers to effortlessly switch between devices without pressing manual buttons or adding extra peripherals-no additional monitors, keyboards, or mouses needed. Keep your workspace clean, efficient, and fully optimized for productivity.
For tech enthusiasts and DIY hobbyists, managing home servers shouldn't be a hassle. Comet gives you direct hardware access from anywhere.
No more crawling into basements or closets just to troubleshoot-stay in control of your Raspberry Pi, home server, or network devices right from your desk. Save time, reduce clutter, and streamline your setup with Comet.
Secure Remote Access While Traveling
Comet provides a seamless way to access your home PC securely from anywhere-without relying on VPNs or dealing with ISP port forwarding restrictions.
Whether you need to maintain a home IP for work compliance or ensure uninterrupted access to your files, Comet keeps you connected with a plug-and-play wired setup. Travel freely while staying securely linked to your home network.
Browser-Based Remote Access
4K Video & Two-Way Audio
Mouse Controls
Mouse Controls
Self-Hosted Lightweight Cloud Option
Comet supports self-hosted deployment on mainstream operating systems such as Linux and Ubuntu, giving you full control over your remote access environment.
Available on firmware version 1.5 and above.
Remote access Comet (GL-RM1) via any browser with self-host server for multi-device management
Comet enables remote power management by connecting to extension devices such as ATX Boards and Fingerbot, allowing users to power on/off, or restart any device-even those without internet connectivity-from anywhere. By eliminating the need for physical access, Comet reduces downtime, ensures seamless operation, and enhances efficiency, reliability, and cost-effectiveness.
The Story behind Comet
When our engineer lost remote access during a critical business trip, they knew there had to be a better way. That's why we created Comet (GL-RM1)—an affordable, plug-and-play remote KVM that works without public IPs, recovers from power outages, and gives you reliable control anytime, anywhere.
If you just want a box to plug in, login to a web page, and start using a system remotely, then this(Comet) worked really well.
pcguide
With the Comet's BIOS/UEFI level compatibility, users can perform tasks like OS installations and troubleshooting without requiring the target system to be operational.
TechRadar
Product Reviews
slide 1 to 3 of 8
Discover how Remote KVM over Internet solutions empower enterprises with secure, efficient, cost-effective IT maintenance.
Comet (GL-RM1) Remote KVM with 4K@30FPS vide resolution providng cost-effective remote IT maintenance solution
Threat Monitoring & Response for Industrial Equipments
Discover how GL.iNet KVM enhances industrial control efficiency, ensuring safety & cutting costs with real-time monitoring.
Threat monitoring and response for industrial equipments with Comet (GL-RM1) from GL.iNet
Compare KVM
Home Lab Comet (GL-RM1)
Comet
 (GL-RM1)
KVM over Internet
Comet PoE
 (GL-RM1PE)
KVM over PoE
Comet Pro
 (GL-RM10)
KVM over Wi-Fi 6
Display
4K@30FPS
4K@30FPS
4K@30FPS
Latency Latency
Latency Latency
30-60ms*
Latency Latency
30-60ms*
Latency Latency
30-60ms*
Two-way Audio Two-way Audio
HD Passthrough HD Passthrough
Display Screen Display Screen
2.22" touchscreen
System & Connectivity
Processor Processor
Processor Processor
Quad-core Cortex-A7
Processor Processor
Quad-core Cortex-A53
Processor Processor
DDR3L 1GB / 8GB eMMC
DDR3L 1GB / 32GB eMMC
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
2.4GHz: 286Mbps
5GHz: 286Mbps
LAN Port LAN Port
LAN Port LAN Port
1Gbps
LAN Port LAN Port
1Gbps
LAN Port LAN Port
1Gbps
Power Input Power Input
Type-C, 5V/2A
Ethernet (PoE) / Type-C,
5V/2A, PD-compatible
Type-C, 5V/2A,
PD-compatible
Dimensions Dimensions
80 x 60 x 17.5mm / 85g
102 x 70 x 22mm / 140g
93 x 84 x 47mm / 170g
4K@30FPS Video Resolution
4K@30FPS
Video Resolution
with 30-60ms latency
One Time Purchase
One Time Purchase
BIOS Access
BIOS Access
USB 2.0 External Extension
USB 2.0
External Extension
Audio Support
Remote
Audio Output
Desktop Application Support
Desktop
Application Support
Gigabit Ethernet
Gigabit
Ethernet
Specifications
Interface 1 x Ethernet port
1 x USB 2.0 port
1 x HD IN port
1 x Type-C power port
1 x Type-C, USB 2.0 port
1 x Reset button
CPU Quad-core ARM Cortex-A7
Memory / Storage DDR3 1GB / 8GB eMMC
Resolution 4K@30fps
Power Input Type-C, 5V/2A
Dimension 80 x 60 x 17.5mm / 85g
Tools & Downloadables Datasheet | App | Product Teaser | Tutorials | Firmware | GitHub | Media Kit | Rack Mount
Policy & Agreement Privacy Policy | User Service Agreement
Looking for Bulk Purchase?
Contact Our Sales Manager
Frequently Asked Questions
Overall rating: 4.917293 / 5 from 133 reviews.
AI Generated Review Summary
The Comet (GL-RM1) Remote Keyboard Video Mouse offers remote control of devices from anywhere, with no subscription fees. It features 4K@30FPS video, ultra-low latency, and remote file transfer. Users appreciate its ease of use and powerful functionalities.
Summary topics
  • Remote KVM (18%): A significant amount of customers expressed appreciation for the remote KVM, describing it as amazing and great.
  • Device Functionality (26%): Many customers expressed appreciation for the device, stating that it is a great little device with amazing functionalities.
Review topics: ["quality","delivery","service","works","support","performance","connection","price","setup","features","control","issues","interface","software","functionality","use","device","kvm","latency","comet","solution","updates","access","app","version","experience","resolution","option","system","videos"].
Review highlights
  • "i like gl-inet products, this kvm works good and fast."Pavel
  • "this is an awesome remote KVM."Mel G.
  • "IT is the exact remote device i have been looking for."Shaun H.
Reviews
Great IP KVM!
"The GL. iNet Comet (GL-RM1) is a stellar upgrade over my older IP KVM solutions, delivering a rock-solid 60 fps at 2K resolution with very low latency control over a standard gigabit LAN. DHCP was enabled out of the box, making setup painless. Firmware updates are super easy, as was adding SSL certificates. I was even able to SSH to the box to automate the certificates. While the "Paste to Remote Device" feature is generally convenient, it occasionally stumbles with slow applications on the host, occasionally messing up what you pasted. Overall, it is a very capable KVM that makes a strong case for me picking up the upcoming 4-port version."
Ted C. (5/5)
excellent
"only the keyboard input could be not once per token for the mcp, like ai doesn't like that, as well as some issues with caps lock for the ai"
Denis B. (5/5)
Amazing way to connect to remote devices
"It works great. Needs to add camera pass through but overall great product. Also the WOL is an amazing feature"
Ahmed W. (5/5)
Fantastic Device
"Well built device that's easy to setup. The UI is very user friendly. Device has been very reliable with no issues so far."
Rhys (5/5)
Excellent Product
"The Comet (GL-RM1) has performed spectacularly throughout my ~1 year use of it. It doesn't require the installation of any applications, saving me from wasting time configuring settings on Remote Desktop applications that run in the background. The latency is excellent and I was able to play games smoothly (though the Comet but on the same local network). The occasional firmware updates have been great, and the Discord community offers quick help with issues and unique feature requests. Some of these requests eventually even become part of the new firmware, and even without requests, some new things still get added, like the new ZeroTier support. Previously at launch, only Tailscale support was implemented, but it wasn't able to be updated unless it was included in a new firmware version. Now with new firmware, we can update tailscale as we wish and we have ZeroTier support. I have been using my Comet with my Reolink PoE NVR system (RLN8-410) and they're both connected via ethernet to an Asus router acting as a Wi-Fi adapter for both devices. Although the Comet Pro would likely perform better in this situation (it has Wi-Fi 6 built-in and so it would no longer need to share a network connection with the NVR), the Comet offers a more affordable and industrial design that can withstand heavier use in a non-ideal environment which suits my needs perfectly. The user-friendly UI and GoodCloud service make this a definite recommend for basic and advanced users."
DaNobody (5/5)
Great KVM overall 4. 9/5 stars
"Great KVM overall. 2 things that can use improvement: A. Allow for copy paste between machines versus just having virtual media. B. 2FA randomly expires and needs to re-login. Setting a pre-defined "trust this device" status should solve it."
Dimitrios D. (5/5)
Awesome Quality
"Would buy this KVM again anytime. Perfect built and nice software"
Andy F. (5/5)
A solid product
"Easy to set up, easy to use. Absolutely no problems so far."
Dvv (5/5)
Love this device, perfect
"Love this device, perfect for a replacement for remote desktop behind a firewall. 2fa available in the latest version and accessible from the browser. Not POE, but you can get a POE splitter to take care of it. I now have three of these devices driving my homelab. Best product I have bought in a few years. I highly recommend."
Neil (5/5)
Great product and even better customer service.
"I’ve been using the GL. iNet Comet Pro Remote KVM over Wi‑Fi along with the Comet (GL‑RM1) Remote Keyboard Video Mouse, and overall I’m really impressed with what these devices can do. I did run into an odd conflict where F11 stopped working in VS Code, but GL. iNet’s support team helped me track it down quickly. Their GLKVM. exe app was intercepting the key globally, and once I knew that, the fix was simple. I ended up switching to the browser interface—which honestly works great and avoids the issue entirely. For anyone who prefers the desktop app, it’s also easy to disable the F11 handler by editing the app. asar file, and support even provided the exact lines to remove and how to repack it. Nice to see a company that gives real, practical solutions instead of runaround answers. With the workaround in place, the Comet Pro has continued to be rock‑solid for remote access, and the KVM performance over Wi‑Fi is surprisingly smooth. Even with that small hiccup, I’m really happy with the setup and appreciate how responsive their support team was in helping me get everything sorted out."
Christopher Q. (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
