$115.99
Original price $115.99 - Original price $115.99
$115.99
Current price $115.99
Meet Comet PoE
Powered-over-Ethernet Remote KVM with 32GB eMMC
Remote KVM over PoE
PoE-Powered - Power & network over a single cable
Tailscale Support - Secure remote networking
32GB eMMC Storage - High-speed, built-in storage
Browser-Based Access - Remote control from Windows, macOS or Linux, no app required
4K@30FPS Video - Crisp visuals with H.264 encoding
Two-Way Audio - Hear and be heard remotely
One-time Purchase - No subscription fees, ever
PoE-Powered Remote KVM
32GB eMMC Storage
Two-way Audio
4K@30FPS Video
Tailscale Support
Dual Power Option
Self-Hosted Option
Comet PoE in homelab setup
using Comet PoE for remote work while traveling
using Comet PoE in server rooms for reduced cable clutter
using Comet PoE in factories to cut hazardous site visits
Maximize Your Homelab with Local Storage & Full Control
With 32GB of onboard eMMC storage, Comet PoE provides ample space for system snapshots, recovery tools, and logging. Homelab users can manage headless servers or custom-built setups efficiently-no need for external storage or complex workarounds.
Manage systems in remote offices or offsite locations through a browser-no apps or complex VPNs required. Comet PoE is ideal for handling updates, troubleshooting, or BIOS-level access across distributed teams or locations.
Streamline Server Rooms with PoE-Powered Simplicity
Simplify deployment with Power over Ethernet (PoE)-just one cable for both power and data. Comet PoE helps IT teams reduce cable clutter and maintain a clean, organized environment, perfect for tight or dense server rack spaces.
Factories & Field Sites
Remotely monitor, control and troubleshoot multiple devices in high-risk or unmanned zones without site visits.
PoE & 1Gbps Ethernet
Deploy with a single cable for both data and power. Perfect for rackmount environments or minimizing cable clutter.
High-Speed 32GB eMMC Storage
Store system logs, snapshots, and even ISO installers with ~35MB/s reading speed-no external drive needed.
Browser-Based Remote Access
4K Video & Two-Way Audio
Mouse Controls
Mouse Controls
Comet PoE supports self-hosted deployment on mainstream operating systems such as Linux and Ubuntu, giving you full control over your remote access environment.
Comet PoE enables remote power management by connecting to extension devices such as ATX Boards and Fingerbot, allowing users to power on/off, or restart any device-even those without internet connectivity-from anywhere. By eliminating the need for physical access, Comet PoE reduces downtime, ensures seamless operation, and enhances efficiency, reliability, and cost-effectiveness.
10 Inch Rack Mount
Bulk Deals or Customized Remote Access Solutions
Let's Connect
What Beta Tester are Saying
Comet PoE (GL-RM1PE) homelab setup with Slate Plus (GL-A1300) and Flint 3 (GL-BE9300) by beta tester
The upgraded 32GB eMMC lets me store ISO installers without hassle, and best of all, the latency is so low it feels like I'm physically connected to it. It's now a permanent addition to my laptop bag when servicing servers in cramped network closets where there's no room for a monitor or keyboard.
@OzTech74L
Comet PoE (GL-RM1PE) with Fingerbot (FGB-01) together for remote device access and management
I was looking for a solution to remotely manage my backup router which doesn't have IPMI.
Paired with a Fingerbot, this product is incredibly efficient and allows me to turn it on/off and control it using web interface. The POE power supply is a real plus, allowing me to take advantage of the UPS without using a dedicated electrical outlet.
@debian1604
Comet PoE (GL-RM1PE) used in homelab setup for remote device access and management
It's been very easy to use. Even my partner who struggled with tech worked it out in a few seconds. The design is very nice and I'll certainly be buying a couple when they go on sale. Nice work!
@yeloop
Compare KVM
Home Lab Comet (GL-RM1)
Comet
(GL-RM1)
KVM over Internet
Comet PoE
(GL-RM1PE)
KVM over PoE
Comet Pro
(GL-RM10)
KVM over Wi-Fi 6
Display
4K@30FPS
4K@30FPS
4K@30FPS
Latency Latency
Latency Latency
30-60ms*
Latency Latency
30-60ms*
Latency Latency
30-60ms*
Two-way Audio Two-way Audio
HD Passthrough HD Passthrough
Display Screen Display Screen
2.22" touchscreen
System & Connectivity
Processor Processor
Processor Processor
Quad-core Cortex-A7
Processor Processor
Quad-core Cortex-A53
Processor Processor
DDR3L 1GB / 8GB eMMC
DDR3L 1GB / 32GB eMMC
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
2.4GHz: 286Mbps
5GHz: 286Mbps
LAN Port LAN Port
LAN Port LAN Port
1Gbps
LAN Port LAN Port
1Gbps
LAN Port LAN Port
1Gbps
Power Input Power Input
Type-C, 5V/2A
Ethernet (PoE) / Type-C,
5V/2A, PD-compatible
Type-C, 5V/2A,
PD-compatible
Dimensions Dimensions
80 x 60 x 17.5mm / 85g
102 x 70 x 22mm / 140g
93 x 84 x 47mm / 170g
PoE
Power-over-Ethernet
4K@30FPS Video Resolution
4K@30FPS
Video Resolution
H.264 hardware encoding
with 30-60ms latency
BIOS Access
BIOS Access
USB 2.0 External Extension
USB 2.0
External Extension
Two-way Audio
Two-way Audio
APP or Browser Access
APP/Browser Access
Gigabit Ethernet
Gigabit
Ethernet
Technical Specifications
Interface 1 x Ethernet port (802.3af/at PoE support)
1 x USB 2.0 Type-A port (for external extension)
1 x USB 2.0 Type-C port (use as USB device)
1 x HD IN port
1 x Reset button
CPU Quad-core ARM Cortex-A53
Resolution 4K@30fps
Power Input Ethernet (PoE) / Type-C (Optional 5V/2A, PD-compatible)
Dimension 102 x 70 x 22mm / 140g
Have a Custom Business Use Case in Mind?
Contact Our Sales Team
Frequently Asked Questions
Overall rating: 4.96 / 5 from 25 reviews.
AI Generated Review Summary
The Comet PoE offers remote KVM control over the internet with PoE power and network over a single cable. It features 32GB eMMC storage, browser-based access, 4K@30FPS video, and two-way audio. Ideal for homelabs, remote offices, and server rooms, it provides full control and management without subscription fees.
Summary topics
  • Device Quality (30%): Many customers stated that the device is excellent, unique, and one of the best on the market.
  • KVM Functionality (34%): A substantial number of customers brought up that the Comet PoE is a great KVM option.
Review topics: ["software","support","works","device","kvm","access","guys","internet"].
Review highlights
  • "The software works well, the device is well constructed, and it was packaged nicely with all the needed cables."Jonathan B.
  • "Best kvm on the market"Joseph J.
  • "The best kvm out on the market."Joseph J.
Reviews
Love them!
"These guys have been performing flawlessly over the past 4 months. I have two of them that I connect to over Tailscale. Remote wake-on-lan + fingerbot is a dream. They get a bit warm though so keep that in mind."
Austin (5/5)
Awesome with one caveat
"Great quality and does everything it has to do. Only caveat is that the Tailscale client is an older version that has known security issues according to Tailscale Portal. Have not had time to check if I can update that myself but for now it is turned off."
Mattias W. (4/5)
Amazing
"I have two of them and I love them! I connect to them through Tailscale and so far everything has worked flawlessly. Remote wake-on-lan and the fingerbot too came in clutch! These guys get warm though, just something to keep in mind."
Austin (5/5)
perfect, no internet required
"works perfectly. Doesn't require internet. Finger bot works. Video streaming works. Full screen in browser is a little tricky thought, but that is, because of how browsers work. Didn't test vpn support, because netbird routes traffic with a node in the same network."
Rick (5/5)
One of the best KVM products
"Really happy with this product. The KVM itself is excellent, the software runs smoothly, the build quality feels solid, and it arrived well-packaged with all the cables included. Honestly, I couldn’t ask for more."
Marek (5/5)
"My new favorite KVM. Does everything and more"
Thomas (5/5)
A good remote control device
"Really nice device, i like how you can control the device, the delay is really small. One thing that could be improved is the resolution and FPS rate so that you can reduce the bandwidth consumption. I like that it has WOL capability and Tailscale. It works from your browser and does the job. A mouse is recommended when using a tablet or a phone."
Florin (5/5)
One of the best KVM-over-IP devices on the market!
"I cannot stress how must more productive I am using this device. My home office already has a PC, monitors, KB&M, mic, and speakers. in an ideal setup, so adding my work laptop to the mix is a problem. This device not only solves the dilemma by being an acceptable KVM, but it allows me to work on my familiar setup. One of the best features is the Speaker and Mic passthrough, as you can bypass the terrible laptop devices. The POE feature is a massive plus, as you use one less cable. All of this at competitive price, and the device is smaller than any "normal" KVM. There really is no better option."
Nicolas K. (5/5)
Remote KVM
"The setup was simple, The device just works."
Alonzo S. (5/5)
A Great KVM
"This Comet PoE is a great KVM, the only issue that i encountred is that i had binding issues with linking the KVM to the Glinet KVM app. I have now a great time with Glinet KVM app and i can acess anytime anywhere my server that is connected to this KVM."
Arp (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
