Puli (GL-XE300) 4G LTE Wireless Security Gateway
$125.99
Original price $125.99 - Original price $125.99
$125.99
Current price $125.99
Puli / GL-XE300
GL-XE300 4G LTE Wireless Router
MEET PULI
4G LTE Portable Wireless IoT Gateway
Puli (GL-XE300) is a portable 4G smart router that is perfect for home, business and IoT solution. With its OpenWrt supported feature and large storage compatibility, it is designed for you to develop DIY IoT project. It also comes with a rechargeable battery, so you can bring it anywhere with you!
300 Mbps Wi-Fi Speed
512GB Max MicroSD
Built-in 5000mAh Battery
Built-in BLE Module (Optional)
Learn More View Online Guide
LTE
Interchangeable Module Tailored to Your Needs
Puli (GL-XE300) router is easily configurable and has a built-in interchangeable module for full optimization. It is compatible with CAT4 and CAT6 modules, which with different downstream throughput and different bands to satisfy your various requirements.
LTE
IPv6 and WPA3 Supported
Puli (GL-XE300) supports the latest version of the Internet Protocol (IPv6), adding an extra layer to your cybersecurity. It also supports WPA3 encryption which is the next generation of Wi-Fi security.
Work or Play Securely Anywhere, and Anytime
Apart from its powerful built-in firewall, Puli (GL-XE300) also supports OpenVPN, WireGuard® and customized DNS server in order to level up your online security. With our brand-new Web UI 3.0, you can set up VPN server easily and access your files securely and remotely.
WireGuard® is a registered trademark by Jason A.Donenfeld.
WireGuard
Max.38Mbps
OpenVPN
Max.10Mbps
Web UI
Cloudflare
ENCRYPTED DNS WITH CLOUDFLARE
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. It serves to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Visit Cloudflare
Cloudflare X GL.iNet
GoodCloud Logo
GoodCloud makes it easy to manage and monitor our devices anytime, anywhere, and multiple GL.iNet devices at the same time. You can view the real-time statistics, setup VPN server and client, manage client connection list, and more through the App or web admin panel.
Learn More
Web Service API
IoT Device Modeling
Control Logic Building
Data Analysis
Remote SSH
Experience seamless connectivity with the Puli*, fully compatible with GL.iNet’s advanced eSIM solution, which supports both physical eSIM cards and integrated eSIM chips*. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security. For consumers, this means effortlessly switching networks and avoiding roaming charges, while businesses benefit from centralized management, multi-device support, and secure data management.
*Products with Quectel EP06-A modules do NOT support eSIM, as the Qualcomm software lacks specific AT command support. For products with EP06-E modules, please refer to this LINK to upgrade to the latest firmware and enable eSIM functionality.
*The feature currently requires pairing a physical eSIM card with our firmware. Integrated eSIM chip is available for bulk orders only.
Easy Configuration with New Web UI 3.0
The built-in 4G modem supports AT command, manual/automatic dial number, SMS checking and signal strength checking for better management and configuration.
AT Command
AT Command
Manual/Automatic Dial Number
SMS checking
SMS checking
Signal Strength Checking
Web Admin Panel
Application Scenarios
Puli (GL-XE300) Reviews
  • Video 0
    Sim Eiotclub provata con il router OpenWrt GL.iNet GL-XE300
  • Video 1
    Trying #EIOTClub SIM Cards Off Grid & Underground
  • Video 2
    Sim Eiotclub router OpenWrt GL.iNet GL-XE300 Proviamoli insieme
  • Video 3
    A FREE Reolink for You! EIOTCLUB Prepaid Sim Card, BizGlobeLink, Mobile Hotspot, loT 4G/5G Data
  • Video 4
    Eiotclub Travel Router with 24GB SIM Card & GL-XE300 Global Router Bundle
OpenWrt Pre-installed
OpenWrt
Pre-installed
External Storage
4G LTE
Module
External Storage
Built-in Battery
(5000mAh)
External Storage
External Storage
Dual Flash
Dual Flash
VPN Client/Server
VPN Client /
Server
Specifications
Interface 1 x WAN Ethernet Port
1 x LAN Ethernet Port
1 x USB 2.0 port
1 x MicroSD card slot (Up to 512GB)
1 x Nano SIM card slot
1 x Reset button
1 x Type-C power port
CPU QCA9531, @650MHz SoC
Memory / Storage DDR2 128MB / NOR Flash 16MB + NAND Flash 128MB
Protocol IEEE 802.11b/g/n
Wi-Fi Speed 300Mbps (2.4GHz)
Wi-Fi Antennas 2 x Internal Antennas
4G Antenna 2 x Internal full-band antennas (700MHz ~ 2.7GHz)
Ethernet Speed 10/100Mbps
LEDs 4 x Power supply indicator, 1 x PWR status indicator, 1 x WAN status indicator,
1 x LAN status indicator, 1 x Wireless status indicator, 1 x 3G/4G status indicator
Power Supply 5V/2A (with battery), 5V/3A (without battery)
Power Consumption <4.4W
Storage Temperature -20 ~ 45°C (-4 ~ 113°F)
Dimension / Weight 120 x 74 x 28mm / 223.5g
Looking for Bulk Purchase?
Connect with our team for volume pricing. Boost your business with GL.iNet’s advanced networking solutions.
  • Customizable and OpenWrt-based
  • Remote Device Management
  • White Label Service
  • Global Product Certifications
  • Self-owned Factory
Contact Our Sales Manager Become a Distributor
Frequently Asked Questions
Overall rating: 4.7647057 / 5 from 17 reviews.
AI Generated Review Summary
The Puli (GL-XE300) 4G LTE Wireless Security Gateway is a portable router praised for its comprehensive configuration options, responsive connectivity, and stable mobile internet access. It is highly regarded for its ease of use and reliability, making it suitable for various applications such as home, business, and IoT solutions.
Summary topics
  • Configuration Extensibility (7%): It was noted by customers that the configuration that is available is fairly comprehensive and extensible with plugins.
  • Device Performance (28%): Based on many customers, this device is a great little device that does just what I want.
  • WiFi Stability (11%): It was noted by customers that the Prefect mobile wifi is stable and covers complete apartment.
  • Connectivity Responsiveness (18%): A significant number of customers pointed out that they were glad to see connectivity very responsive and immediate.
  • Mobile Internet Access (14%): Customers expressed satisfaction with the mobile internet access provided by the device, as it was a perfect solution for their needs.
Review topics: [connection, support, wifi, issues, battery, device, configuration, access, router, ports, team].
Review highlights
  • "Whenever I need a secure 4G cellular mobile internet access, this is my preferred device."Hardjono T.
  • "A full features portable 4G cellular mobile device!!!"Hardjono T.
  • "Great little device for security cameras"Amy T.
Reviews
Very positive experience.
"Very positive experience. I contacted GL. iNet support regarding a fairly specific issue involving a GL-XE300 router, its LTE modem, and eSIM management. The support team was extremely precise and professional. They followed the issue carefully, provided clear and technically accurate instructions, and helped me troubleshoot the problem step by step. What I appreciated most was their technical competence and the fact that they did not simply provide generic answers. They actually investigated the issue and stayed focused on it until it was resolved. In the end, I was able to configure the device correctly and solve all the problems I had encountered. Overall, a very positive experience. Having knowledgeable and responsive technical support really makes a difference, especially when dealing with less common or more advanced configurations. Highly recommended."
Marvin (5/5)
great travel router for 4G
"Very satisfied with the product. Wifi is stable and covers complete apartment. VPn connection is also very stable, no breaking packet loss. I used SIM card provider and vpn connection and it was working great and as expected. I bought version with battery, and this keeps him ON for 6-7h on 4G connection, which is really nice thing. This product is very good one."
Baki (5/5)
Great little device, does just
"Great little device, does just what I want, and most impressively seems to mostly do it the WAY that I'd want too! I chose the 4G model for price and to avoid huge aerials. The integral battery is an absolute must, the 4-way options for upstream connectivity is what I was after, and crucially it works very smoothly with the SMARTY SIM inserted. Had zero problems using it abroad in Europe, too. One "nice to have" that I'd look for in an updated version would be the ability to add repeater WiFi Networks which would auto-login on networks with a landing page. Doesn't matter about the few that have stupidly complicated landing pages, but where it's easy to auto log in, that'd be a huge plus."
J L. (4/5)
Amazing
"What a great bit of kit, just amazing, perfect Battery, love the RJ45 ports."
Michael G. (5/5)
Very Dependable
"I was glad to see connectivity very responsive and immediate. I had no issues configuring the router with my phone. It also works great with my laptop. I know it has helped to use the Puli more than the other GLiNet model router I had before. I hope you keep this model in stock for replacements. Thanks."
Nicholas F. (5/5)
Perfect for my mobile internet access needs!
"Whenever I need a secure 4G cellular mobile internet access, this is my preferred device. With the LAN port build-in, you can avoid using WIFI access altogether. Just using LAN port for even more secure wired LAN connection. A full features portable 4G cellular mobile device!!! Two thumbs Up!"
Hardjono T. (5/5)
Great Buy
"I really like this router, it is compact enough to carry around in your pocket used with the physical esim card for data and works well as a static router in an hotel. setting up the VPN is easy. I had an issue with the esim and some questions before I bought it and the support was excellent. I would recommend it."
Clive S. (5/5)
Great little router
"I'm using this for a DIY project involving remote monitoring of power consumption and needed an LTE router to install in the field. Once I got the right cell provider (T-Mobile for me in the US) the Puli simply set itself up after powering on and was ready to use with no additional configuration necessary on my end. That said, the configuration that is available is fairly comprehensive and extensible with plugins. Overall I'm very pleased!"
Jesse F. (5/5)
I absolutely love this modem!
"I absolutely love this modem! The OS is based on openwrt, and is really flexible. Love the ethernet ports. If I get to troubleshoot a PC without wireless capabilities, it's super easy to get it online via cable with this thing. Overall, great product!"
Bohdan S. (5/5)
Great gadget
"Your mobile access to all private networks (home, office, company, . . . ). Extensible by OpenWRT's packages. Also possible to connect to Ethernet wire."
Kamil K. (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
