$419.99
Original price $419.99 - Original price $419.99
$419.99
Current price $419.99
Meet Mudi 7
Product Code NA Version (GL-E5800NA) EU Version (GL-E5800EU)
WCDMA B1 / B5 / B8
Next-Gen Connectivity
Anytime, on the go
Up to 13.5h Battery Life: 5380mAh capacity with 24W PD fast charging
Tri-band
Wi-Fi 7
5765Mbps
6GHz
2882Mbps
5GHz
688Mbps
2.4GHz
5G Connectivity
2.8” LCD Touchscreen
Dual SIM Dual Standby
Up to 13.5hrs Run Time
2 USB-C Ports
2.5G LAN/WAN Port
High-speed VPN
OpenVPN-DCO
700+ Mbps
WireGuard®
600+ Mbps
eSIM
Activate, connect, share
5G meets tri-band Wi-Fi 7
Secure, stable, and always on
slide 1 to 2 of 4
Dual-SIM backup, eSIM flexibility
Switch networks instantly
Mudi 7 delivers the stability you need via dual-SIM dual-standby, and the freedom you want with built-in eSIM—letting you switch carriers instantly without ever touching a physical card.
One-tap carrier connection
Seamless SIM & eSIM toggle
Connect your way, with versatility
slide 1 to 2 of 4
Stop struggling with outlets
Equipped with a 5380mAh battery, Mudi 7 doesn't rely on power outlets. It recharges via 24W PD fast charging, minimizing downtime.
Download the 3D-printable wall mount and effortlessly mount your device anywhere you need it, with or without a battery cover.
Wall Mount Bracket
Mudi 7 (GL-E5800) Reviews
    The Newest Travel Routers...
What Beta Testers are Saying
tar_xvf
What I love most is the ecosystem—I host my own VPN server on GL-iNet hardware at home and connect the Mudi 7 to it from wherever I am. It’s the ultimate setup for working abroad. The built-in LAN port is also a huge plus for privacy; by hardwiring my laptop, I can kill the wireless radios and keep my location completely off the grid.
@tar_xvf
amuzyche
This seemingly mobile router provides connectivity not only for laptops and TVs but for an entire smart home ecosystem. Handling work by day, 4K streaming by night, and simultaneous climate/lighting control is effortless.
@amuzyche
Vulcan
I can’t say enough good things about the Mudi 7. I needed something dependable for work on the go, but it’s quickly turned into our family’s all-around internet solution.
@Vulcan
mmavis29
Pocket‑friendly and simple to set up, it pairs solid hardware and mature software with quick, reliable Wi‑Fi and consistently strong VPN performance. The long battery life means fewer outlets and more productivity on the go. In short, it’s the ultimate mobile router—a must‑have travel companion.
@mmavis29
_DaNobody
The most underrated accessory included with each Mudi 7 is the travel case. It protected my Mudi 7 from the heavy rain while only having surface moisture on the outside. Unfortunately the rain got to my books and soaked them, but the travel case having protected my Mudi 7 gives me peace whenever I travel with it. Absolute 10/10 in my opinion.
@_DaNobody
admonstrator
It is most effective during on-site client visits: When I'm working directly at a server room rack, I use it to hook up to the internet on my own. This bypasses the need for local firewall configurations, and the built-in VPN ensures that I always have secure access to our company servers. I can easily access my secure data and tools without compromising the client's infrastructure.
@admonstrator
tomp5138
We had 36 tablets, 14 laptops and 1 printer connected over WiFi to the mudi, plus a Poe switch on the ethernet port connected to 6 Poe cameras and a comet Poe. Spectators were able to live stream the event from the cameras and get real time results, all passed through the mudi. And just to add this was all on battery the entire time.
@tomp5138
mniko_tech
Battery life has been excellent – it easily lasts through long travel days and extended usage, which is exactly what I was hoping for in a mobile router. Performance has been stable, and I especially appreciate the support for the latest channels, which helps maintain strong and reliable connections in different environments.
@mniko_tech
jl_blackbriar
Arrived at an Airbnb, first thing unpacked is the Mudi7.
@jl_blackbriar
Earendilsi
At home, I use it in tethering mode with my Flint 3, ensuring a reliable backup connection ready to take over if my fiber line goes down. As always, GL‑iNet’s interface is outstanding: clean, intuitive, and powerful.
@Earendilsi
bonedaddy4538
The Mudi 7 is a game changing device that puts other 5G hotspots to shame. The features are unmatched and will perform in the most demanding use-cases.
@bonedaddy4538
Up to 4.67 Gbps 5G NR
Up to 4.67 Gbps
5G NR
Tri-band Wi-Fi 7 BE5800
Tri-band Wi-Fi 7
BE5800*
2.5Gbps Ethernet Port
2.5 Gbps
Ethernet Port
10 Gbps USB 3.1
10 Gbps
USB 3.1
OpenWrt Pre-installed
OpenWrt
Support
VPN Client / Server
VPN Client /
Server
eSIM Support
eSIM Support
Fast Charging
Fast Charging
*Dual-band Simultaneous (DBS) Wi-Fi 7 BE5800: 2.4GHz Only, 5GHz Only, 6GHz Only, 2.4GHz+5GHz, 2.4GHz+6GHz
Technical Specifications
Mudi 7(GL-E5800) 5G NR Frequency Bands
WCDMA B1 / B5 / B8
2 x Nano SIM Card Slots
1 x Onboard eSIM Chipset
2 x TS-9 Ports
1 x Power Button
1 x Reset Button
Memory/Storage LPDDR4X 2GB / 8GB eMMC
eSIM 1 x Onboard eSIM
Built-in Battery 3.85V/5380mAh/20.72Wh
Power Consumption <30W
Frequently Asked Questions
Overall rating: 4.810811 / 5 from 37 reviews.
AI Generated Review Summary
Summary topics
Review topics: ["delivery","service","features","works","setup","support","performance","issues","battery","speed","connection","router","functionality","hardware","wifi","device","choice","unit","modem","switch","videos","ports","guys","inet","option"].
Review highlights
Reviews
Das beste was es gibt
"Ich behaupte einer der besten Geräte die ich bis anhin hatte, ausreifend am Testen, im Wlan 🛜 wie auch beim verhalten der E-Sim. Ausgezeichnete Arbeit an das Team. Einfach Gerätesprache noch auch auf Deutsch bringen. Kann es wärmstens empfehlen den Mudi7"
Liborio L. (5/5)
Mudi 7 — My recommendation!
"I just received my Mudi 7. There were some delivery issues in Germany, but thanks to the amazing GL. iNET support, they were resolved successfully. I just started using my Mudi 7. Setup is easy, and my initial experience shows very good performance. I’m very happy with this product and recommend it."
Patrick D. (5/5)
Awesome device for mobile live video production
"I'm always in awe about the versatility of the GL*iNet devices. What blows me away: You can have the device create a private Wifi network while acting as a repeater for another one. I take an NDI-in-a-box system to various event venues. It can connect my production system to hardwire, wireless and even 5G networks while providing all the network infrastructure the NDI-in-a-box needs."
Oliver B. (5/5)
Full function
"So far I love it. This hotspot has more customization options than anyone could ever want and near perfect band compatibility for all US carrier. I haven't tested AT&T or Verizon yet but both of their IMEI checkers claim that it won't work - it's the same for T-Mobile's checker but it still works. GL. iNet has been very open with their IP/software on the Mudi 7 so they give you access to tinker with anything you could ever want. Only gripe I have, and it's a major one, is replacement batteries are not sold and likely never will be so I have had to spend a lot of time searching online for a battery of similar size that I am going to have to heavily modify for it to work."
Jesse H. (4/5)
"A great addition to add to my Campervan after purchasing an all inclusive E-Sim package. It was easy to install following the online instructions, but also has 2 physical SIM card ports. More importantly it also features 2 MIMO ports so an external antenna can be fitted, offering a greater single range. Long life battery and also USB C powered. An excellent bit of kit if you don't want a designated motorhome hard install. This can also be taken abroad and used as a personal WiFi hotspot."
Robert (5/5)
Extremely capable
"Awesome device. Lots of functions and settings, VON, etc. Really great. But, VERY big. I wish it would be smaller to be able to carry it around easier. It doesn’t fit in pocket. But don’t get me wrong. I fully recommend"
Ariel E. (5/5)
Fantastic
"I love it. It Performs very well on network connectivity. Long battery live about 12 hours of use. It has a Fancy looks, just like a smartphone in hands. I mistakely often time press it on the side to have the screen light on, just because it feels like smartphone when I hold it. By its appearance, I was skeptical about absence of antennas on it , but for my surprise, it beats my Spliz xe3000 on connectivity rate and network performance. Gl-INet has scored higher again with this MUDI 7: router, cellular router, modem, access point, tethering, repeater, and wifi extender, all in one device, yes ! The SIM card works very well in both slot and it's easy to maintain the connection locked into a chosen 5g Nr Network Tower, even after many reboots. I often find myself doing "some fancy switch from one devise to another" because I am sometimes confusedby their both similar performances (my Mudi 7 and my Spliz xe3000 ) I'm a lover of GL-INET because of their performance and the freedom of manipulation they give us."
Guest C. (5/5)
The Ultimate Portable 5G Wi‑Fi 7 Travel Router
"The GL. iNet Mudi 7 is a pocket‑sized 5G Wi‑Fi 7 travel router that feels like a major portability upgrade over the Slate 7, with the added flexibility to run on battery or directly via USB‑C passthrough. It’s light (around 300 g), compact, and offers up to ~13–17 hours of battery life depending on load, while still supporting battery‑free operation for minimal bulk when plugged in. Connectivity is excellent for travel: two nano‑SIM slots plus built‑in eSIM, dual‑SIM standby, and easy switching between 5G, Wi‑Fi repeater, and Ethernet WAN via the 2. 8″ touchscreen. Performance is strong for a travel device, with 5G speeds up to 4. 67 Gbps, tri‑band Wi‑Fi 7, a 2. 5 GbE port, and OpenWrt‑based VPN support for secure remote work. If you’re coming from the Slate 7, the Mudi 7 is a clear step up in portability, power options, and SIM/eSIM flexibility, making it one of the best all‑in‑one mobile routers for digital nomads."
Bobo (5/5)
Good device, Amazon shipping was bad
"The device is great but the shipping through Amazon was a bad experience. There were no updates for multiple weeks on the shipping and then it updated at some point and told me it was delivered 10 days ago and I had to dig deeper to find out it was delivered to a neighbor but it wouldn't even tell me which neighbor so I had to ring at least 5 different neighbors to find out who had received it. I was expecting it got lost because the situation it felt so sketchy. Very glad when I finally found the neighbor who had the package."
Claas M. (4/5)
Good product for all
"Very excellent product. And the service is also perfect. Mudi 7 is a good choice for you. Just buy it to start your next trip."
JIANAN (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
