Flint 4 (GL-BE14000) Tri-band Wi-Fi 7 Home Router
$369.99
Original price $369.99 - Original price $369.99
$369.99
Current price $369.99
Meet Flint 4
BE14000 Tri-band Wi-Fi 7 Home Router
*Flint 4 is currently unavailable in the U.S. due to recent FCC-related developments. For details, please refer to our official statement.
The High-Performance Home Network Hub
Flint 4 (GL-BE14000) redefines what a home router can be. More than a fast Wi-Fi router, it is built to serve as the high-performance core of modern home networks. Designed for demanding homes, power users, SOHO setups, and light business environments, Flint 4 is built for networks that need more than ordinary routers can deliver.
Tri-band Wi-Fi 7 with MLO: Max. 688 Mbps (2.4 GHz) + 4,323 Mbps (5 GHz) + 8,646 Mbps (6 GHz)
Complete Multi-Gig Wired Backbone: 1 x 10G SFP+ WAN/LAN, 1 x 10GE WAN/LAN, 1 x 2.5GE WAN/LAN, 3 x 2.5GE LAN and 4 x 1GE LAN
High-Performance VPN: Up to 1.5 Gbps on WireGuard® and OpenVPN DCO
2.4" Touchscreen Display: Real-time network status monitoring and at-a-glance visibility across your network, right on the device.
Get the Highlights
Tri-Band
Wi-Fi 7
2.4GHz: 688Mbps
5GHz: 4,323Mbps
6GHz: 8,646Mbps
Built for high-speed wired performance
2.4-inch Touchscreen
Real-time status at a glance
Blazing-Fast VPN
Up to 1.5 Gbps VPN
  • Multi-tunnel
  • VPN Failover
  • Enhanced Kill Switch
VLAN Segmentation
Advanced
DPI Shield
64GB Flash
Dual USB 3.0
USB-C Expansion
IoT Network
Tri-Band Wi-Fi 7, Built for More
Flint 4 leverages tri-band Wi-Fi 7 to deliver a faster, smoother, and more responsive wireless experience for modern high-load networks. With support for 2.4 GHz, 5 GHz, and 6 GHz, plus Multi-Link Operation (MLO), it gives every device more bandwidth to perform at its best while helping reduce congestion, improve responsiveness, and maintain network stability under heavier demand.
Wi-Fi 7
6 GHz
8646 Mbps
5 GHz
4323 Mbps
2.4 GHz
688 Mbps
WI-FI COVERAGE
Coverage up to 3,100 sq ft
Designed to provide strong, reliable wireless coverage across larger homes and more demanding environments.
*Coverage estimates are based on testing in an open environment. Actual coverage varies with building materials, layout, and interference.
DEVICES CONNECTED
Connect over 250 devices smoothly
Flint 4 is built for high-capacity performance, helping smart TVs, laptops, phones, and IoT devices stay fast and reliable even in busy multi-user environments.
*Device capacity figures are based on testing in a controlled lab environment. Actual results may vary depending on devices, usage, and network conditions.
10G SFP+ 10GE WAN/LAN 2.5GE WAN/LAN 3 x 2.5GE LAN 4 x 1GE LAN
High-Performance VPN, Without the Usual Trade-Offs
Flint 4 is built to deliver high-speed VPN performance for users who expect both security and speed. With up to 1.5 Gbps on WireGuard® and OpenVPN DCO, it helps protect your privacy, enable secure remote access, and support more advanced network use without the slowdowns often associated with traditional VPN routers.
Up to 1.5 Gbps VPN
Built-in OpenVPN DCO acceleration ensures faster encryption and smoother performance for remote work, travel, and privacy-focused users.
Tests conducted on a local network. Real world speeds may differ depending on your network configuration.
OpenVPN and WireGuard speeds will be slower when running the device as a server. Results above are in client mode.
Supports 30+ VPN services with OpenVPN and WireGuard® in both client and server modes
Smarter VPN Routing and Protection
Multi-Channel Concurrency with Policy-Based Routing
Concurrent VPN Tunnels with Policy-Based Routing
Run multiple VPN connections simultaneously and apply different routing policies to all clients, specified connection types, specified devices, or all devices except those you exclude.
Multi-Profile Selection and Automatic Failover
Select multiple profiles within a tunnel, and traffic will automatically switch to the next available profile if the current one becomes unavailable, helping keep the connection stable and reliable.
Kill Switch Protection
When enabled, Kill Switch Protection helps ensure all traffic remains inside the VPN tunnel by automatically blocking any connection that would otherwise bypass the VPN.
Unlock Flexible, Customizable Networking
Built on OpenWrt 21.02 (Kernel Version 5.4), Flint 4 delivers a more flexible and customizable networking experience. With broad plugin support and advanced configuration options, it gives users more ways to tailor features, expand capabilities, and shape the network around their needs.
Flint 4 Advanced Home Network Customization
Shape your network around the way you actually use it.
Flint 4 Plugin Expansion and Feature Flexibility
Add more functionality as your network needs evolve.
Flint 4 VPN Policy and Advanced Routing
Control how traffic moves across your network.
Flint 4 Smarter Flow Control
With DPI Engine, Data Statistics, Content Filter, QoS, and SQM, Flint 4 helps users understand traffic, prioritize what matters most, and reduce latency under load.
Flint 4 AdGuard Home
AdGuard Home
Enjoy a faster, safer, and cleaner web experience with AdGuard Home built into Flint 4. It helps block intrusive ads, stops trackers from following your online activity, and adds protection against phishing and malware-related threats — so browsing feels more private, less distracting, and better protected.
2.4-inch Touchscreen, Real-Time Status at a Glance
Flint 4 features a built-in 2.4-inch touchscreen that brings real-time network status and essential controls directly to the device. Check DPI status, traffic data, and other key details at a glance, without opening the web admin panel. From toggling VPNs and sharing Wi-Fi to monitoring system status, the touchscreen makes everyday control faster, simpler, and more immediate from the moment you power on.
Flint 4 2.4-inch Touchscreen, Real-Time Status at a Glance
Get Started Instantly, No App Required
Enjoy a more direct setup experience with key functions accessible right on the device.
Simplified VLAN Setup
Make network segmentation easier to manage with more accessible on-device controls.
100× More Storage
Most home routers offer only 256MB to 512MB of Flash — enough for basic firmware, but limited for expansion. With 64GB of onboard Flash, Flint 4 delivers over 100× More Storage, making more room for OpenWrt packages, richer logs, and more capable local services.
Flint 4
Flint 4
64GB
Typical home routers
256MB-512MB
Flint 4 Stay Online with Backup Connectivity
Use one USB port to connect a 4G / 5G dongle or mobile hotspot for failover. For small businesses and home offices, this creates a practical backup internet option that helps keep work running when the main connection goes down.
Flint 4 Add Lightweight Private Cloud Storage
Use the second USB port to connect an SSD, external drive, or USB flash drive. With support for Samba, WebDAV, DLNA, Flint 4 can provide a low-cost way to enable shared storage, local file access, and smoother data transfer across the home or office.
Flint 4 (GL-BE14000) Reviews
  • Gl.iNet Flint 4 Monster Router is Real
  • Day 1 at CES! 🔴LIVE!
  • Flint 4 SFP+ Unboxing Wifi performance Iperf3 GL-BE14000
What Beta Testers are Saying
mnavis29
The 10G SFP+ and 10GbE RJ45 combo is brilliant. I’ve got my multi-gig fiber line feeding directly into my local NAS switch setup with zero bottlenecks.
@mnavis29
ashoruk89
As a technical enthusiast running a high-performance smart home on a 2.3 Gbps symmetrical fiber connection, the GL.iNet Flint 4 (GL-BE14000) has completely redefined my network's capabilities. The hardware profile is stellar. Having access to multiple 10Gbps and multi-gigabit switch ports means I can finally saturate my full ISP line speed right out of the box.
@ashoruk89
Oztech74L
Move over OPNSENSE/FLINT 2, FLINT 4 is my new favourite.
@Oztech74L
phantasm2222
GL.iNet have come up with a masterpiece of engineering with the Flint 4. Not only do you get a gorgeous router with an LCD touchscreen along with 10 GBE and 64GB flash, you get a world class router, capable of exceeding 2Gbps with OpenVPN connections.
@phantasm2222
ziotidus
Flint 4 (GL-BE14000) is a fantastic step up from the Flint 2, with noticeably better Wi-Fi coverage and speed, lower latency, and rock-solid stability across every device I tested. It stays cool and silent even under heavy use, handles advanced networking setups like VLAN segmentation with ease, and easily saturates my 2.5Gbps homelab connection without a single hiccup.
@ziotidus
LupusE
Flint4 is a real improvement in the home network. If you have no special needs, just plug in, open the Web interface and connect to the ISP or upstream router. You'll get a fast central network node, to connect multiple 2,5GB devices and one 10GB SPF+ for a NAS or similar.
@LupusE
leo.sfsm
Its Wi-Fi 7 capabilities and robust signal strength represent a significant leap over previous-generation devices that once you experience it, there’s truly no going back. And thanks to its polished interface, I can quickly deploy VPNs, configure dedicated VLANs, and fine-tune advanced network settings with just a few clicks.
@leo.sfsm
Punajurrikka
Performance was consistently fast and stable, with excellent Wi-Fi coverage and solid VPN throughput. The hardware feels premium and the software is easy to use, although the router can get a bit warm under load. Overall, it's a powerful router with great potential, and I'm looking forward to the official release and continued software improvements.
@Punajurrikka
torvi9607
The Flint 4 is an absolute powerhouse, easy to set up and jam packed with features you’d expect in enterprise hardware. My Wi-Fi has never been so good!
@torvi9607
BMV_12
I have a very demanding environment, not only in terms of networking equipment, but also the physical structure of my house. The Flint 4 was piggy backing off of my 10Gig home network and was the forefront of my homelab test environment. The Flint 4 was physically located at the top level of a 3 storey house and was still able to produce a strong wifi signal that allowed me to connect to even in the ground floor.
@BMV_12
Product Comparison
New Flint 4 (GL-BE14000)
Flint 4
(GL-BE14000)
Flint 3 (GL-BE9300)
Flint 3
(GL-BE9300)
BE9300 Tri-band Wi-Fi 7 Home Router
Flint 2 (GL-MT6000)
Flint 2
(GL-MT6000)
High-Performance Wi-Fi 6 Router
CPU
CPU
MediaTek, Quad-core @1.8 GHz
CPU
Qualcomm, Quad-core @1.5 GHz
CPU
MediaTek, Quad-core @2.0 GHz
Memory / Storage
Memory / Storage
DDR4 2GB / eMMC 64 GB
Memory / Storage
DDR4 1 GB / eMMC 8 GB
Memory / Storage
Wi-Fi Coverage
Wi-Fi Coverage
Up to 3,100 sq ft
Wi-Fi Coverage
Up to 2,000 sq ft
Wi-Fi Coverage
Up to 1,500 sq ft
Wi-Fi Speed
Wi-Fi Speed
Wi-Fi Speed
Max. 688 Mbps (2.4 GHz) + 2,882 Mbps (5 GHz) + 5,765 Mbps (6 GHz)
Wi-Fi Speed
Max. 1148 Mbps (2.4 GHz) + 4,804 Mbps (5 GHz)
WireGuard® Speed
WireGuard® Speed
Max. 1500 Mbps
WireGuard® Speed
Max. 680 Mbps
WireGuard® Speed
Max. 900 Mbps
OpenVPN Speed
OpenVPN Speed
Max. 1500 Mbps (with DCO support)
OpenVPN Speed
Max. 680 Mbps (with DCO support)
OpenVPN Speed
Max. 880 Mbps (with DCO support)
Touchscreen
Touchscreen
Touchscreen
Touchscreen
Ethernet Ports
Ethernet Ports
1 x 10G WAN/LAN Ethernet Port
1 x 10G SFP+ WAN/LAN Port
1 x 2.5G WAN/LAN Ethernet Port
3 x 2.5G LAN Ethernet Ports
4 x 1G LAN Ethernet Ports
Ethernet Ports
1 x 2.5G WAN Ethernet Port
Ethernet Ports
4 x LAN Ethernet Ports
Device Capacity
Device Capacity
Up to 250 concurrent devices
Device Capacity
Up to 124 concurrent devices
Device Capacity
Up to 86 concurrent devices
Tri-band Wi-Fi 7
Tri-band Wi-Fi 7
Touchscreen
Touchscreen
10Gbps SFP+
10Gbps SFP+
OpenWrt Support
OpenWrt
Support
VPN Client / Server
VPN Client /
Server
VLAN
VLAN
10Gbps Ethernet Port
10Gbps
Ethernet Port
2.5Gbps Ethernet Ports
2.5Gbps
Ethernet Ports
Specifications
Interface 1 x 10G WAN/LAN Ethernet Port
1 x USB 3.0 Port (Type-A)
1 x USB 3.0 Port (Type-C)
1 x Reset Button
1 x Power Button
CPU MediaTek Quad-Core Cortex-A73 @ 1.8GHz
Memory / Storage DDR4 2 GB / eMMC 64 GB
Wi-Fi Speed 688 Mbps (2.4 GHz), 4323 Mbps (5 GHz), 8646 Mbps (6 GHz)
Ethernet Speed 10/100/1000/2500/10000 Mbps
Antennas 6 x Foldable External Wi-Fi Antennas
Power Input 12V/4A
Power Consumption Without USB Load: <25W
With USB Load: <45W
Dimension / Weight 293 x 172 x 76mm / 1166g
Frequently Asked Questions
Overall rating: 4.857143 / 5 from 14 reviews.
AI Generated Review Summary
Summary topics
Review topics: ["hardware","performance","features","router","power","package","flint 4","throughput","firmware"].
Review highlights
Reviews
Awesome hardware
"Fantastic router. I previously used the Netgear R7800 with OpenWrt because the original firmware lacked features. The Flint 4 has such a comprehensive system that installing anything else makes no sense. It's fast, very stable, and I've never once managed to get it hot enough to activate the built-in fan. It's a bit pricey, but it's definitely worth the price."
SqTER (5/5)
The Flint 4: The Mature Router I've Been Waiting For
"After owning the Flint 2, Flint 3E, and Flint 3, all of which are excellent routers, I always felt that each one was missing something. With the Flint 4, however, I finally found the mature, complete router I had been waiting for. Everything I wanted from the previous models is finally here: 10G WAN? ✅ Yes! 2. 5G LAN? ✅ Yes! WiFi coverage that reaches every corner of the house? ✅ Absolutely! Enough processing power and memory to handle all the advanced features and functions? ✅ Definitely! GL. iNet has also added a nice extra: a touchscreen display. It's surprisingly useful for monitoring and managing key router functions without needing a PC or smartphone nearby. I directly compared the Flint 4 with the Flint 3 in terms of speed, features, and WiFi coverage, and the results were clear: the Flint 4 comes out on top in every category. Bottom line: the Flint 4 feels like the culmination of the entire Flint series. It's powerful, feature-rich, and finally delivers everything I was looking for in a router without compromises. ⭐⭐⭐⭐⭐ Highly recommended!"
Enrico S. (5/5)
Great Wi-Fi 7 Router
"While this is still based on the same software as other GL. inet Flint routers (of which I own several), this has MUCH improved management for the LANs and ports, and much more visual way to manage the router as a whole. While there are still improvements that can be made, I think that this is the best, and latest demonstration of the commitment of GL. inet to making routers that are top of the line from both hardware, and software. I look forward to them continuing to innovate, especially on the software side, now that the hardware is this good. This router reaffirms why I have now standardized my installation of GL. inet."
Frank A. (5/5)
My first GliNet Router
"It´s my first Router from GLiNet and I am very pleased. I experienced no hiccups, was blown away by the possibilities thru OpenWRT and if I were not in the mood to tinker the default interface was easy to navigate while being packed with features."
Janic F. (5/5)
Most reliable Home Router
"Feature packed. No issues whatsoever. Most reliable router I used. I definitely recommend and will happily buy again. Keep making great products GLiNet."
Dani J. (5/5)
Excellent Performance, however hope it
"Excellent Performance, however hope it can suppose MESH asap. I would like to plan to have full house Flint 3 & 4 running mesh"
Lam K. (5/5)
best router!
"best router ever!"
Olaf (5/5)
Pure power for a reasonable price with an old OpenWRT fork
"Having previously upgraded my Flint 2 to Vanilla OpenWrt to overcome the limitations of the heavily modified OEM firmware—such as outdated APK management, older kernel versions, missing security patches, and the lack of proper packet steering and WLAN WED support—I was really hoping the Flint 4 would bring a modernized software foundation out of the box. Unfortunately, that is not entirely the case. GL. iNet is still shipping this device on a heavily customized OpenWrt 21 base. While the stock Web UI and mobile app remain intuitive and user-friendly, the underlying OS legacy causes the same familiar friction points regarding kernel features, package management, and system efficiency. On top of the software legacy, the implementation of MLO (Multi-Link Operation) is currently hit-or-miss. Clients are frequently tossed between bands, causing noticeable micro-stutters and brief dropouts during daily use. That being said, hardware-wise, the value proposition is incredible. The price-to-performance ratio is top-tier, raw network throughput is solid, and the stock interface makes basic network management effortless. It gets a strong 4 out of 5 stars because the overall physical package and performance are genuinely positive, but GL. iNet desperately needs to bring their core firmware base up to modern OpenWrt standards and polish the MLO stability."
Csaba H. (4/5)
Excellent hardware with excellent software
"This router works with the Nokia G-010S-A despite the ungrounded"
Alexander D. (5/5)
Good, yet not perfect
"The Flint 4 is an absolute beast of a router. It is quite expensive, so I’m glad I managed to get it during the Super Early Bird campaign, but the hardware you get is incredibly capable. Starting with the software, I was quite disappointed to see that the Flint 4 still runs OpenWrt 21. I was coming from a Flint 2, where the stock firmware was already based on OpenWrt 25, so this definitely felt like a step backwards. I assume the main reason is the Wi-Fi implementation. The wireless side is handled in a non-standard way, using a custom MediaTek driver, and it is configured through a custom LuCI application (`luci_app_mtk`) rather than the usual OpenWrt Wireless tab. This becomes particularly annoying when configuring Wi-Fi roaming. It can still be done, but the process is considerably more complicated than it should be. On the hardware side, however, there is very little to complain about. There are ports everywhere, so you can connect pretty much anything you could possibly need. Build quality is excellent, the materials feel premium, and the display is a very nice touch that makes the whole product feel even more high-end. Then we get to a couple of surprisingly basic shortcomings: * On the Flint 2, the wall-mount slots allow the router to be mounted in either orientation. On the Flint 4, they only work in one direction, which means the router is officially meant to be mounted with the ports facing upwards. That makes absolutely no sense to me. By using screws with larger heads and spacing them very carefully, I managed to mount it with the ports facing downwards anyway, but it is far from ideal. * Closely related to that, there is no option to rotate the display by 180 degrees. I can understand why this may not have been considered, since the hardware itself is designed to be mounted in only one orientation, but still. . . the users buying this kind of router are hardly basic users. If mounting it upside down cannot be properly supported, at the very least please give us the option to rotate the display! There is definitely some room for improvement, but overall I am very satisfied with it. P. S. Needless to say, Wi-Fi 7 with MLO works extremely well. The hardware is incredibly powerful; GL. iNet just needs to polish a few aspects of the product. Above all, the software really needs to be brought up to date."
Alessandro B. (4/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
