Spitz AX (GL-X3000) Wi-Fi 6 AX3000 | 5G NR | Dual-SIM failover
$379.99
Original price $379.99 - Original price $379.99
$379.99
Current price $379.99
GL-X3000 Wi-Fi 6 Cellular Gateway
MEET Spitz AX
Wi-Fi 6 Dual-SIM 4G/5G Cellular Gateway
Reliable Cellular Networks in Rural Areas
GL-X3000 is a Wi-Fi 6 cellular gateway designed to provide reliable cellular networks in remote locations and high speed internet in urban areas. It has six external antennas for long range connection, two SIM Cards for selecting between the ISP with stronger connections, and Multi-WAN between the WAN port, SIM Card, and Repeater.
Supports 5G NR & Multi-WAN
Dual-SIM, Single Modem
Wi-Fi 6 Max. 574 Mbps (2.4GHz) + 2402 Mbps (5GHz) Wi-Fi Speeds
OpenVPN speed up to 150 Mbps; WireGuard speed up to 300 Mbps
Learn More View Online Guide
Module: RM520N-GL
5G NR NSA n1/ 2/ 3/ 5/ 7/ 8/ 12/ 13/ 14/ 18/ 20/ 25/ 26/ 28/ 29/ 30/ 38/ 40/ 41/ 48/ 66/ 70/ 71/ 75/ 76/ 77/ 78/ 79
LTE LTE-FDD B1/ 2/ 3/ 4/ 5/ 7/ 8/ 12/ 13/ 14/ 17/ 18/ 19/ 20/ 25/ 26/ 28/ 29/ 30/ 32/ 66/ 71
LTE-TDD B34/ 38/ 39/ 40/ 41/ 42/ 43/ 48
LAA B46
UMTS WCDMA B1/ 2/ 4/ 5/ 8/ 19
GNSS GPS/ GLONASS/ BDS/ Galileo/ QZSS
Module: EM160R-GL
LTE LTE-FDD B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B17/B18/B19/B20/B25/B26/B28/B29①/B30/B32①/B66
LTE-TDD B38/B39/B40/B41/B42/B43/B46① (LAA)/B48 (CBRS)
DL 2CA Intra-band and Inter-band
DL 3CA Intra-band and Inter-band
DL 4CA Intra-band and Inter-band
DL 5CA Intra-band and Inter-band within 5 bands
DL 4×4 MIMO B1/B2/B3/B4/B7/B25/B30/B32①/B38/B39/B40/B41/B66
DL 256QAM Supported
UL 2CA Intra-band
UL 64QAM Supported
UMTS WCDMA B1/B2/B3/B4/B5/B6/B8/B19
GNSS GPS/GLONASS/BeiDou(COMPASS)/Galileo
Notes: ①: For secondary component carrier only.
Recreational Vehicles(RV) Deployment
Spitz AX is your reliable router on the road, working in an RV. Spitz AX allows you to access multiple WAN connectivity, switching easily between the WAN port, SIM cards, and Repeater. It has 6 external antennas to increase connectivity. When an amplifier is needed for extra stability of your internet services in remote locations, Spitz AX can connect to an extended GPS antenna or wired dome antenna of your choice. To secure your secured network gateway on a bumpy ride, you can easily deploy Spitz AX to your RV's interior walls.
Dual SIM for selecting the ISP with stronger connections
Fast Wi-Fi 6 connection for all the devices in the RVs
Secure network when connecting to a public Wi-Fi
Compatible with the Best RV Antennas in the Industry
GL.iNet partnered with the industry's top RV antenna manufacturers to ensure seamless communication no matter where your journey takes you. Stay connected, stream, browse, and share memories on the road without interruption.
RV Use
Model: LTMWG942 (Black / White)
Learn More
Home/RV Use
Model: Low-Profile Omni 4x4 MIMO Antenna
Learn More
Home/RV Use
Model: High-Gain Directional 4x4 MIMO Antenna
Learn More
Spitz AX is pre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. It automatically encrypts all network traffic within the connected network, including guest or client devices that are not capable of running VPN. Spitz AX can also host VPN servers and supports VPN Cascading, automatically forwarding data from its VPN server to the VPN client within the same device.
WireGuard
Max. 300Mbps
OpenVPN
Max. 150Mbps
Our local network storage feature supports SMB Protocol and WebDAV protocol. By plugging an external USB hard disc into the router, you can create a private network to store and share your documents. No matter for work or family, you can benefit from easy file access. Save space on your devices by storing photos and videos on the network.
Spitz AX runs on GL.iNet's latest SDK4.0+ firmware and presents a user-friendly interface for common users to set up the router with minimal inputs, and an extended customization experience for advanced users to install plug-ins and applications. Spitz AX runs on GL.iNet's proprietary firmware based on OpenWrt (v21.02 Kernel version 5.4), supporting more than 5,000 ready-made plug-ins for customization. Simply browse, install, and manage packages with our no-code interface within the Admin Panel.
Everyday Scenario for Spitz AX
Remote Work
VPN cascading for you to access your company’s local server remotely
Rural Areas
Stable and long-range network connection using multi-WAN & antennas in your sizeable country house
Road Trips
Dual SIM cards to switch data services for your group in a snap
Co-working space
Secure your confidential data and network speed while using public Wi-Fi Services
Block Ads & Tracking for Free
AdGuard Home Ready on Router
AdGuard on admin panel
Block ads for all client devices
Block online trackers and analytics by default
Block age-restricted content and services as needed
Customizable DNS filters
Keep sensitive online data safe
Enforce family browsing security
Visit AdGuard
PREVENT MAN-IN-THE-MIDDLE ATTACKS
DNS over TLS & DNS over HTTPS
Spitz AX supports both DNS over TLS and DNS over HTTPS to enhance network privacy and security, providing users with the flexibility to choose between encryption depending on the network type. DNS over TLS uses encryption to secure DNS communications, while DNS over HTTPS uses the HTTPS protocol for an additional layer of security.
Remote Access and Management
Spitz AX comes with GL.iNet's GoodCloud remote device & networks management platform, providing users with data usage monitoring and technical support services with remote access to the device admin panel for maintenance and troubleshooting. It also enables batch device management, firmware updates, analytics and notifications for status updates, enabling users to manage devices efficiently.
DFS Certification in US, CA, EU and UK
Spitz AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications. The selection of additional channels can lower network congestion under high density network environments.
Empowering IoT Connectivity with Customizable BLE, Thread, and Zigbee Integration
The Spitz AX offers IoT customization options including BLE, Thread, and Zigbee protocols. While customization is a key aspect of the Spitz AX, it is important to note that this feature is exclusively available for bulk orders.
Carrier Certified IoT Device
Spitz AX is certified by T-Mobile and AT&T under the IoT device category, and is therefore compatible with these network providers. Spitz AX’s IoT application is supported and interoperable with these network infrastructures, ensuring seamless connectivity and reducing the risk of connectivity issues.
Experience seamless connectivity with the Spitz AX, fully compatible with GL.iNet’s advanced eSIM solution, which supports both physical eSIM cards and integrated eSIM chips*. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security. For consumers, this means effortlessly switching networks and avoiding roaming charges, while businesses benefit from centralized management, multi-device support, and secure data management.
*The feature currently requires pairing a physical eSIM card with our firmware. Integrated eSIM chip is available for bulk orders only.
Model Comparison
Spitz / GL-X750V2
4G LTE Smart Router
VS
Spitz AX / GL-X3000
Wi-Fi 6 4G/5G Router
QCA9531, @650MHz CPU MediaTek Dual-core, @1.3GHz
DDR2 128MB / NOR Flash 16MB Memory / Storage DDR4 512 MB / EMMC 8GB
IEEE 802.11a/b/g/n/ac Protocol IEEE 802.11a/b/g/n/ac/ax
300Mbps (2.4GHz), 433Mbps (5GHz) Wi-Fi Speed 574Mbps (2.4GHz), 2402Mbps (5GHz)
10/100Mbps Ethernet Speed WAN Port: 10/100/1000/2500Mbps
LAN Port: 10/100/1000Mbps
1 x WAN, 1 x LAN Ethernet Ports 1 x 2.5Gbps WAN, 1 x LAN
Max.512GB TF Card Slot Max.1TB
1 x Micro SIM card slot SIM Card Slot 2 x Nano SIM card slots
Max.10Mbps OpenVPN (Via Ethernet) Max.150Mbps
Max. 38Mbps WireGuard® (Via Ethernet) Max. 300Mbps
Spitz AX (GL-X3000) Reviews
  • Ultimate RV Internet Setup: Triple WAN Router Changes Everything
  • Why You Need a New Internet Gateway
  • Take your WiFi with you! GL.iNet Beryl AX & Spitz AX
  • THE ULTIMATE MOBILE INTERNET SETUP?
  • Our 5G Campervan WiFi Setup - With the GL.iNet Spitz AX Router (GL-X3000)
  • Don’t buy 5G Netgear M6 or RUTX50 without watching this first! Spitz AX GL-X3000 5G Router Review
  • AX Spitz 5G Router Review
  • Gl.INet GL-X3000NR overview
  • Notre solution INTERNET et WIFI dans notre camping-car !!! GL-X3000 SPITZ AX
  • MOBILE INTERNET Woes - New 5G Upgrade: Has it fixed it?
    5G NR Module
    *5G NR
    Module
    IoT
    #IoT
    OpenWrt Pre-installed
    OpenWrt
    Pre-installed
    Wi-Fi 6
    Wi-Fi 6
    VPN Client/Server
    VPN Client /
    Server
    AdGuard
    AdGuard
    MU-MIMO
    MU-MIMO
    DFS
    DFS
    * The Spitz AX is available in two versions: 4G LTE (CAT16) and 5G NR (CAT19).
    # Customization options are also available for bulk orders.
    The cellular feature in Spitz AX (GL-X3000) is restricted in Russia, Belarus, Cuba, Iran, North Korea, Syria, and the Crimean Peninsula due to modem limitations.
    Specifications
    1 x LAN Ethernet port
    1 x USB 2.0 port
    1 x MicroSD card slot (Max.1TB)
    1 x Reset button
    Memory / Storage DDR4 512 MB / eMMC 8GB
    Ethernet Speed WAN Port: 10/100/1000/2500Mbps LAN Port: 10/100/1000Mbps
    Antennas 4 x Cellular Antennas (SMA, 600M~6GHz)
    2 x Wi-Fi Antennas (PR-SMA, 2.4G~2.5GHz, 5.15~5.84GHz)
    LEDs System / 5G Wi-Fi / 2.4G Wi-Fi / Internet / Cellular Signal Strength
    Power Input DC5521, 12V/2.5A (5.5*2.1mm) [default adapter] / 9~36V
    Power Consumption <14W
    Dimension / Weight 155 x 95 x 36mm / 520g
    Looking for Bulk Purchase?
    Contact Our Sales Manager
    Frequently Asked Questions
    Overall rating: 4.850467 / 5 from 107 reviews.
    AI Generated Review Summary
    The Spitz AX (GL-X3000) Wi-Fi 6 AX3000 is a highly regarded 5G NR dual-SIM cellular gateway, praised for its powerful performance and ease of setup. It offers reliable and fast internet connectivity, especially in rural areas, with multiple WAN options and advanced features like load balancing and failover. The device is also equipped with robust security features, including support for OpenVPN and WireGuard, and it runs on OpenWrt 21.02 firmware, allowing for extensive customization.
    Summary topics
    • Device Performance (15%): Many customers remarked that they absolutely love this device and find it to be very powerful and easy to set up.
    • Connection Speed (12%): Customers expressed satisfaction with the speed of the Spitz AX (GL-X3000) Wi-Fi 6.
    • Router Quality (38%): A substantial number of customers brought up that the router is one of the best 5G routers in the market.
    • Product Features (6%): Customers keep praising the great features of the product, which is a common opinion among the reviews.
    • Network Connection (11%): It was highlighted by customers that the connection is super strong and fast, with outstanding speed.
    Review topics: [results, quality, delivery, works, service, connection, speed, price, support, features, interface, issues, performance, software, functionality, use, setup, using, router, signal, device, internet, unit, antennas, data, coverage, sim card, team, sim, settings].
    Review highlights
    • "Easy to use, good looking and powerful router for reasonable price!"Kaspars L.
    • "It was super fast connecting to local 5G network and distribute with outstanding speed."Hailu M.
    • "Great speeds using it as a repeater and I love the cellular features."Teszra T.
    Reviews
    Spitz AX
    "5/5 Stars – Exceptional Performance & Fast Internet! Spitz AX (GL-iNet GL-X3000) Review I’ve been testing the Spitz AX and the results are simply outstanding. Best router performance I’ve seen so far! Speed: Reached impressive speeds of 458Mbps download / 69Mbps upload. Low latency, stable connection, and zero lag even during heavy usage. Heavy Usage Test: Handled 475 GB of traffic throughout July without a single drop, slowdown, or need for a reboot. Rock-solid stability under heavy load! Overall Impression: Excellent Wi-Fi 6 coverage, reliable 5G connection, and top-tier features for power users. Verdict: 5-star product. Outstanding performance, super fast internet, and high reliability. Highly recommended!"
    Vasilev L. (5/5)
    Bester Router den ich je hatte!
    "Ich habe mir den x3000-Spitz mit einer Dachantenne in meinem Wohnwagen eingebaut. Ich bin begeistert wie alles läuft, auch Wireguard mit meiner Fritzbox 5690 pro zuhause, Streaming alles funktioniert bestens. Die Umschaltzeit bei Wifi-Ausfall ist legendär, im TV ist noch nicht ein Flackern zu bemerken!"
    Dieter S. (5/5)
    Great Support and Product
    "We had an esim problem and support quickly responded with a couple of emails to sort it out and is now all, working great. We are very impressed with how quick and good the response from yourselves at GL-inet has been. We really like the GLX3000 for is spec, quality and reliabilty. With the SIMPOYO physical esim card and a profile from Esim from ETravelSim we have great performance Roaming in Europe. Speeds of 169Mb download and 81Mb upload. Can't beat, all on an unlimited cheap 5-30 day contract. Well done GL-inet and your partners."
    Rob M. (5/5)
    Static caravan
    "Initially I was sceptical with this router. Mobile signal is very poor on campsite. On setting it up it was just receiving the same 2mbps as my teltonika router which is connected to a poynting xpol exterior antenna. However with this router it was able to scan the nearby mobile antennas and tell me which one was 5g and that it was an O2 tower. I then switched the sim from smarty (3 provider) to giffgaff (O2 provider) and instant change occurred. This router was able to pick up 5g signal- without the need of external mobile antennas- and boosted the 2 mbps to 50mbps. Amazing. Now have removed both teltonika router and external poynting antenna, which had cost me £300 combined 2 years ago, that give me poor internet connection. Now only have the GL. inet router to replace them both. Now have fantastic internet connection. Can’t recommend enough as long as you combine it with a sim that is compatible with 5g tower provider"
    Gary H. (5/5)
    Nice
    "I haven’t set it up yet but it came in highly recommended for my purpose. I’m giving all five now until further notice."
    Besent N. (5/5)
    GL-Inet really stands behind their product!
    "Great product, amazing support from gl-inet. It's fantastic to see a company that really stands behind their product."
    Michael S. (5/5)
    Top quality. . . automatic self-adjustment. . highly
    "Top quality. . . automatic self-adjustment. . highly recommended to everyone"
    DARKO G. (5/5)
    Great Product
    "My wife and I are full time RV'ers depending on cellular internet for service. We are using the Spitz X3000 and it is amazing. We stream all of our TV, online gaming and do Social Media (probably a lot more than we should) without any problems. This device actually out performs the Peplink B One G we were using prior to purchase. The X3000 has been great with no issues to date. Fast, reliable, and solid performance. If you are on the fence trying to decide to purchase a device, I would suggest joining the GL-iNet forum to get some great information on any of their products."
    Cary M. (5/5)
    No insurmountable issues as of yet.
    "I have no real complaints about this router. Setup was a breezea and configuration options are plentiful. It strikes the perfect balance between customization and simplicity, meaning neither a techy nor non-techy person should have any trouble setting up a network. The only issue I encountered, and only once (so far) was possibly due to the carrier (T-Mobile via The Calyx Institute), where the internet connection simply dropped for about 15 min. Considering that a reboot of the router didn't fix the issue, I'm inclined to blame the carrier."
    David E. (5/5)
    Installed this in a new
    "Installed this in a new RV both for day to day internet use as well as an alternative to the installation of a roof top satellite dish for TV viewing. Just road tested it across the EU and it has been superb. Ease of set-up and functionality is second to none. The use of multiple eSims and the WiFi repeater has provided me with continuous fast internet throughout the whole trip. I particularly like the VPN function - again so easy to set up."
    Mr S. (5/5)
    Q&A
    • Free Local Shipping
      Fast delivery
    • Rewards on Every Order
      2 points for every $1 spent
    • 2-Year Warranty
      Reliable product coverage
    • 30-Day Returns
      Fast and easy refunds
