Slate 7 Pro (GL-BE10000) Tri-band Wi-Fi 7 Travel Router
$239.99
Original price $239.99 - Original price $239.99
$239.99
Current price $239.99
Meet Slate 7 Pro
*Slate 7 Pro is currently unavailable in the U.S. due to recent FCC-related developments. For details, please refer to our official statement.
World's First True Tri-band Travel Router
Slate 7 Pro (GL-BE10000) is the world’s first travel router to redefine the limits of networking by unleashing the full power of tri-band Wi-Fi 7 aggregation. Equipped with an intuitive 2.8" touchscreen, it allows you to manage key network functions with a single tap. Beyond speed, it provides pro-grade security through integrated DPI and high-speed VPN to safeguard your privacy in any environment. With Slate 7 Pro, you don’t just connect to the world—you challenge its boundaries. Choose your office, secure your data, and embrace the freedom to work from anywhere without compromise.
Tri-band Wi-Fi 7 with MLO: Faster and more stable connections using tri-band aggregation and Multi-Link Operation.
Intuitive 2.8" Touchscreen: Real-time monitoring and one-tap basic network management.
High-Speed VPN with Obfuscation: Up to 1100 Mbps (WireGuard®) with obfuscation to bypass restrictions.
Advanced Network Security: Integrated DPI to easily identify and block malicious traffic.
Open-Source Customization: OpenWrt support for professional-grade flexibility and plugin support.
Seamless Wired Connectivity: Dual 2.5G ports and a versatile Type-C 3.0 data port.
Wi-Fi 7
Advanced Tri-Band Connectivity
Blazing-Fast VPN
Max. 1100 Mbps
Smart Touch Interface
VPN Obfuscation
Bypass Traffic Inspection
OpenWrt-based SDK
Flexible
Customization
Advanced
DPI Shield
Tri-band Aggregation
Dual 2.5G Ports
Boosted Wired Connections
Multi-WAN
Failover
One-Tap Network Control
Slate 7 Pro makes networking effortless with its responsive 2.8" touchscreen. Manage essential features directly on-device to save time and effort. Instantly toggle VPNs, share Wi-Fi, and monitor status with a single touch, giving you immediate control the moment you power on.
Get Started Instantly, No App Required
From Power-On to Connection—No App Required
Toggle VPNs and Switch Providers in Seconds
Pro DPI Security, Compactly Delivered
Slate 7 Pro delivers professional-level precision in a sleek, compact design. By integrating Deep Packet Inspection (DPI), it moves beyond basic tracking to analyze data in real-time—giving you the power to monitor and protect your network, anywhere.
Intuitive Traffic Insights with Visual Precision
Smart Web & Content Filtering
Optimized Bandwidth Management
Stable Connections for Critical Tasks
slide 3 to 4 of 4
Always-On, High-Speed Networking
Slate 7 Pro features dual 2.5G ports—including one configurable WAN/LAN—and a USB-C port for tethering, enabling fast, flexible connectivity with seamless Multi-WAN failover.
Mission-Critical Reliability for Business Travel
High-Bandwidth Production in the Field
Professional-Grade Home Lab & Remote Work
Unlock Open-Source Networking Freedom
Built on OpenWrt 21.02 (Kernel Version 5.4.281) with 1GB DDR4 RAM and 512MB NAND Flash, Slate 7 Pro offers full open-source support, giving developers and advanced users the freedom to inspect, modify, and evolve its system capabilities through extensive plugin support and deep customization.
forbes
Whether it’s operating under strict network controls or the user wants greater privacy with uninterrupted access, the Slate 7 Pro is the way to do that, especially when on the move or working away from home or office.
forbes
Slate 7 Pro (GL-BE10000) Reviews
  • Testing The New Slate 7 Pro! @GLTechnologies
  • Doom on the Slate 7 Pro Travel Router - GL-BE10000 GL-iNet
  • Gl.iNet Slate 7 Pro Should You Buy - 5 PROs and 5 CONs!
  • Gl.iNet Slate 7 Pro Travel Router - SHOULD YOU BUY?
What Beta Testers are Saying
LupusE
The display is a pro. Compared to the small display of the Slate 7, the QR Code can be scanned with every phone, even from a photo of the screen. It is small and travel friendly, I like the new power supply.
@LupusE
DarkHawk
I think the hardware is great...the device is very sturdy and has a nicely sized screen.
@DarkHawk
tharty
The Slate 7 Pro isn't just the perfect travel router, it's an absolute powerhouse capable of driving my home network with ease!
@tharty
mniko_tech
Hardware quality is excellent and thermal behaviour is well controlled even under heavy load.
@mniko_tech
Model Comparison
Slate 7 (GL-BE3600)
Slate 7 / GL-BE3600
VS
Slate 7 Pro / GL-BE10000
Qualcomm, Quad-core @1.1 GHz
CPU CPU
CPU CPU
MediaTek, Quad-core @2.0 GHz
2.22 inch
Touchscreen Size Touchscreen Size
2.8 inch
688Mbps(2.4 GHz), 2882Mbps(5 GHz)
Ethernet Speed Wi-Fi Speed
688Mbps (2.4 GHz), 2882Mbps (5 GHz), 5764Mbps (6 GHz)
Max.385 Mbps
OpenVPN-DCO (Via Ethernet) OpenVPN-DCO Speed
Max.1000 Mbps
Max.490 Mbps
WireGuard® Speed WireGuard® Speed
Max.1100 Mbps
VPN Obfuscation VPN Obfuscation
DPI Integration DPI Integration
USB 3.0, 5V/1.5A
USB Port USB Port
USB Port USB Port
USB 3.0, 5V/2A
130 x 91 x 34mm / 295g
Dimension / Weight Dimension / Weight
130 x 91 x 36mm / 328g
Tri-band Wi-Fi 7
Tri-band Wi-Fi 7
Touchscreen
Touchscreen
DPI
DPI
Multi-Link
Operation
VPN Client Server
VPN Client /
Server
OpenWrt Support
OpenWrt
Support
Dual 2.5G Ethernet Ports
Dual 2.5G
Ethernet Ports
PD Power Supply
PD Power Supply
Specifications
Interface 1 x 2.5G WAN Ethernet port
1 x 2.5G LAN Ethernet port
1 x USB 3.0 Type-C port
1 x Type-C Power port
1 x Reset button
1 x Toggle button
Memory / Storage DDR4 1GB / NAND Flash 512MB
Antennas 2 x foldable external Wi-Fi antennas
Power Input USB PD 5V/3A, 9V/3A, 12V/2.5A
Power Consumption < 20W (without USB)
Dimension / Weight 130 x 91 x 36mm / 328g
Tools & Downloadables Datasheet | Firmware | App | Tutorials | Media Kit
Frequently Asked Questions
Overall rating: 4.9 / 5 from 10 reviews.
AI Generated Review Summary
Summary topics
Review topics: [support, performance, setup, router, slate, slate 7].
Review highlights
Reviews
Promising start, very satisfied so far!
"I’ve just finished setting up the Slate 7 Pro and running a few basic tests. So far, the experience has been very smooth. Setup was quick and straightforward, and the initial performance looks extremely promising. I’m really happy with the purchase so far and look forward to using it more!"
Róbert B. (5/5)
Great product
"Immediately as soon as i received it, I was immediately impressed by the interface, enabled LuCI and had openwrt access where I could properly set up the slate without worrying custom scripts and wireguard interfaces (i use netbird). I was a bit bummed about the openwrt version though, its a 2021-2022 version that is heavily modified by you guys, which is not a major issue but its missing a lot of updates from later versions. I am also happy to say that with every feature it has I actually felt a little bit more secure in my activities outside the house. I am still discovering the router as it is brand new in my gadget arsenal but I am loving every single thing about it"
Andreas K. (5/5)
Outstanding Router & Exceptional Technical Support
"The GL-BE10000 is a fantastic Wi-Fi 7 travel router. Fast, stable, feature-rich, and easy to use. I would also like to thank Calvin and the entire GL. iNet Technical Support Team for their excellent support throughout the troubleshooting process. They were professional, patient, responsive, and truly committed to helping resolve my issue. Highly recommended!"
Gary (5/5)
Slate 7 Pro, the best!
"The best router I've had so far. I've owned routers from other brands that left a lot to be desired. I also have the standard Slate 7, but the Slate 7 Pro is better. I have the ISP's router in the living room and the Slate 7 Pro in the office—separated by a few walls—yet I get the same speed as if I were in the living room. Simply fantastic."
Valdimar (5/5)
Great travel essential
"Paired with a Berle 3 at home the slate is great to VPN tunnel by back to my home internet. A+ for setup and reliability"
Ian F. (5/5)
Amazing travel router
"It is super convenient for traveling if you have a lot of devices that need to share a local network. I also set it as a Tailscale exit node and turned on AdGuard Home so I can have a low-latency DNS proxy server to handle all the ad blocking, even while traveling!"
Mike C. (4/5)
Another model, another win for GL-inet
"The Slate 7 Pro has yet again made me realize just how much a small jump from a Slate 7 to a Pro can make. From the top LED screen, the new power inside the casing, and new in innovations, I cannot recommend this enough. As someone who travels both stateside and internationally often, I feel safe and secure using this product while abroad. It’s lightweight, easy to configure, easy to setup and use, and makes connectivity more secure. I’d highly recommend this!"
Joey (5/5)
"Amazing. It's insane what you can do with this travel router in this format. Can't wait for the future firmware updates to add even more."
Olivier (5/5)
small but powerful
"love the performance and happy to get back the MediaTek hardware! small, but powerful travel companion, recommended (not only) for travelers! :)"
GLiNETuser (5/5)
Brilliant
"True tri band wi-fi 7 travel router. Brill VPN and other options and DPI."
offy (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
