Comet X (GL-RM4PE) Quad-Port Remote KVM with PoE
Sold out
$279.99
Original price $279.99 - Original price $279.99
$279.99
Current price $279.99
Meet Comet X
Quad-Port Remote KVM with PoE Support
Quad-Port Remote Control: Control up to 4 servers from anywhere in 4K@30 FPS via browser or app.
PoE-Powered Setup: Power over Ethernet simplifies installation and reduces cable clutter in your rack.
Rack-Ready Design: Fits into rack-mounted setups and integrates easily with your existing server environment.
Touchscreen Interface: Tap to view device IP, online/offline status, and active sessions at a glance.
Local Control: Connect a keyboard, mouse, and monitor for local troubleshooting, setup, or OS installation.
64 GB eMMC Storage: Built-in image repository for ISO storage, OS deployment, and emergency recovery.
Quad-Port
Remote Control
PoE-Powered
Setup
At-a-Glance Touchscreen
Rack-Ready Design
4K HDMI
Passthrough
64 GB eMMC
Storage
Local Control
Flexible Remote
Access
Remote Control for 4 Servers, with Less Clutter.
Control up to 4 servers from a single device. Comet X reduces extra hardware and cable clutter while giving you remote access to connected servers from anywhere.
Before
Four Servers. Four KVMs.
Separate KVM devices for each server create cable clutter and make rack management more difficult.
After
Four Servers. One KVM.
Consolidate remote access and local console control into one compact device.
Made for Every Server Setup
Support client servers remotely and reduce unnecessary site visits.
Troubleshoot, maintain, and recover office servers faster with remote and local access.
Manage multiple home servers from one device and keep your setup cleaner.
msp-clients-sites-left
server-rooms-left
homelabs-left
PoE-powered rack installation for Comet X
Cleaner Setup. Fewer Cables.
Power Comet X through Ethernet for a simpler, more organized rack installation. If PoE becomes unavailable, USB-C 5V backup power automatically takes over to keep Comet X powered.
Rack-ready from day one.
Comet X fits into rack-mounted setups and works seamlessly with your existing server environment.
Built-in Touchscreen for Easier Device Management
View connection status and IP address instantly.
Live Screen Preview
Check the display of any connected device whenever needed.
System Settings
Access essential Comet X controls with ease.
Local Control When You're There.
Remote access keeps you covered when you're away. When you're nearby, connect a keyboard, mouse, and monitor to Comet X for local troubleshooting, setup, or OS installation. Press the front-panel button to quickly switch between connected servers.
Comet X (GL-RM4PE) Reviews
  • Gl.iNet Comet X Multi Client KVM - OH BE STILL MY BEATING HEART!!!
  • Comet X The Holy Grail of KVM? (GL-RM4PE)
  • Gl.iNet Comet X - A REAL Multi-Client KVM for $202?
  • Gl.iNet Comet X KVM $200+ KVM - MORE TESTS, TEARDOWN, POWER USE, SOFTWARE UPDATES, NOISE, PoE v USB
  • GL.iNet Comet Q + Comet X: The Kickstarter KVM Deal You Should Know About
  • KVM 4 en 1 GL.iNet Comet X, Sonoff Zigbee, Epomaker
  • Remote control 4 computers, anywhere (ft Comet X)
What Beta Testers are Saying
OzTech74L
Comet X is the product I envisioned the moment I first used the original Comet PoE. The same fast and responsive KVM experience, but now with four systems at my fingertips. No cable swapping, no compromises, just seamless control.
@OzTech74L
Clint
As in IT professional, it is somewhat of a pain point if your headless devices become unresponsive, and while workplaces have the ability/budget to utilise enterprise level hardware to mitigate this, it's hasn't been as feasible in a home-lab scenario from a cost perspective until the introduction of small KVMs such as the Comet RM1. The GLi-Net team has expanded its offerings in products to understand their target audience, and designed a 4-in-1 version of the original Comet RM1, called the Comet X. This has reduced my need to have multiple Comet RM1/Pro in a single rack for multiple devices, and all easily manageable in a single interface. The product is fantastic and meets the designed use case!
@Clint
ziotidus
I've been using the Comet X as part of my homelab setup, mainly for out-of-band remote management of my Proxmox server. The KVM functionality has been a game changer — being able to access the BIOS/console remotely, even when the system is unresponsive, has saved me more than once. Build quality and stability have been excellent throughout the testing period, and it's now a permanent part of my infrastructure. Really happy with the product!
@ziotidus
LupusE
Before the Comet series was a great way to have access to servers laptops and computers, without leaving the office or home. The Comet X goes one step further and not only provides reliable and fast remote control: At my office desktop I am able to have less cables and devices and use up to 4 systems via HDMI/USB at onemonitor/mouse/keyboard. Plus the remote control via browser, when I am not at home.
Power over Ethernet brings this one step further for less cables around a clean desktop.
@LupusE
Compare KVMs
IT Maintenance
Comet X (GL-RM4PE)
Comet X
 (GL-RM4PE)
IT Maintenance
Comet PoE (GL-RM1PE)
Comet PoE
 (GL-RM1PE)
Remote KVM with PoE
Display
4K@30 FPS
4K@30 FPS
Latency Latency
Latency Latency
30-60 ms*
Latency Latency
30-60 ms*
Two-way Audio Two-way Audio
HD Passthrough HD Passthrough
Display Screen Display Screen
3.69 in, touchscreen
System & Connectivity
Processor Processor
Processor Processor
ARM Cortex, quad-core
Processor Processor
DDR3L 1 GB / eMMC 64 GB
DDR3L 1 GB / eMMC 32 GB
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
Wi-Fi Wi-Fi
Cellular Cellular
Cellular Cellular
Cellular Cellular
LAN Port LAN Port
LAN Port LAN Port
1 Gbps
LAN Port LAN Port
1 Gbps
Power Input Power Input
Ethernet (PoE) / Type-C, 5V/3A
Ethernet (PoE) / Type-C PD, 5V/2A
Dimensions Dimensions
170*90*40 mm / 560g
102*70*22 mm / 140g
Power-over-Ethernet
Power-over-
Ethernet
4-Server Control
4-Server
Control
Touchscreen
Touchscreen
Display
BIOS Access
BIOS Access
4K@30 FPS HDMI Passthrough
4K@30 FPS
HDMI Passthrough
RTailscale/Zerotier/Netbird
Tailscale/Zerotier/
Netbird
APP or Browser Access
APP/Browser
Access
Self-hosted Deployment
Self-hosted
Deployment
Technical Specifications
Interface 3 x Front USB 2.0 Type-A Ports (For local keyboard, mouse, and USB device access)
4 x Rear USB 2.0 Type-A Ports (For connecting peripherals and other accessories)
4 x USB 2.0 Type-C Device Ports (For connection to host computers)
4 x HDMI IN
1 x HDMI OUT
1 x 1 Gbps (802.3af/at PoE support)
1 x USB-C Power Port (Optional 5V/3A, PD-compatible)
1 x Function Button
Operating System Linux-6.1
CPU Quad-core ARM Cortex-A53
Memory / Storage DDR3L 1 GB / eMMC 64 GB
Display Screen 3.69 inch, TFT touchscreen
Ethernet Port 1 x RJ45
Ethernet Speed 10/100/1000 Mbps
Resolution 4K@30 FPS
Power Input Ethernet (PoE)
USB-C (Optional 5V/3A, PD-compatible)
Dimension 170 x 90 x 40 mm / 560g
Rack Mounting Compatible with 10-inch and 19-inch racks; brackets for both sizes included
Tools & Downloadables Datasheet | Firmware | App | Tutorials | Media Kit
Frequently Asked Questions
Overall rating: 5.0 / 5 from 3 reviews.
AI Generated Review Summary
Summary topics
Review topics: [].
Review highlights
Reviews
"Super 4er KVM nach langer Warrezeit erhalten"
Stefan (5/5)
Awesome
"Awesome"
Kevin D. (5/5)
Couldn't be happier
"Couldn't be happier"
DL (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
