$125.99
Original price $125.99 - Original price $125.99
$125.99
Current price $125.99
Spitz (GL-X750)
GL-X750V2 4G LTE Smart Router
MEET SPITZ
Connecting Traditional Devices to the Internet
4G LTE Smart Router
Spitz is a 3G/4G dual-band wireless router, widely used for smart home and IoT area. Running OpenWRT OS, you can compile your own firmware to fit for different application scenarios. It has built-in mini PCIe 3G/4G module to support different operators and can be used all over the world.
Spitz (GL-X750V2) is the advanced version of Spitz (GL-X750). It comes with the redesigned PCBA and optimized antennas to improve the 4G performance.
300Mbps (2.4GHz) + 433Mbps (5GHz) Combined Wi-Fi Speed
128GB MicroSD Capacity
PCIe 4G LTE Modem
Learn More View Online Guide
Boost Your Holiday Experience
Providing a secure Internet connectivity and media sharing solution for fun-filled family getaways
Roadtrip Vaction Home
Work or Play Securely from Anywhere, Anytime
Apart from its powerful built-in firewall, Spitz also supports OpenVPN, WireGuard and customized DNS server to level up your online security. With our brand-new Web UI 3.0, you can set up VPN server easily and access your files securely via a remote site as if you are at home.
WireGuard® is a registered trademark of Jason A. Donenfeld.
WireGuard
Max.38Mbps
OpenVPN
Max.10Mbps
WebUI
Wi-Fi for Things
Bringing Robust Network Connections to IoT World
Smart Logistics POS Transportation
IoT Icon
Facilitating Secure IoT Communications
Spitz creates a secure network for devices that process sensitive information such as ATMs, Point-of-Sales (POS) and more, encrypting their 4G LTE or Wi-Fi traffic via a VPN tunnel for secure access to the Internet or remote services.
CUSTOMIZE YOUR INTERNET USER CASE
Interchangeable Module Tailored To Your Needs
Spitz router is easily configurable and has a built-in interchangeable module for full optimization. It is compatible with CAT4 and CAT6 modules from various brands.
PCIe Module
Cloudflare
ENCRYPTED DNS WITH CLOUDFLARE
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. The goal of the method is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Visit Cloudflare
Cloudflare x GL.iNet
Experience seamless connectivity with the Spitz*, fully compatible with GL.iNet’s advanced eSIM solution, which supports both physical eSIM cards and integrated eSIM chips*. eSIMs can be programmed remotely, offering unmatched convenience, flexibility, space-saving, and enhanced security. For consumers, this means effortlessly switching networks and avoiding roaming charges, while businesses benefit from centralized management, multi-device support, and secure data management.
*Products with Quectel EP06-A modules do NOT support eSIM, as the Qualcomm software lacks specific AT command support. For products with EP06-E modules, please refer to this LINK to upgrade to the latest firmware and enable eSIM functionality.
*The feature currently requires pairing a physical eSIM card with our firmware. Integrated eSIM chip is available for bulk orders only.
Difference between Spitz (GL-X750) and Spitz (GL-X750V2)
Spitz
(GL-X750)
4G LTE Smart Gateway
Spitz
(GL-X750V2)
  • Dual-band wireless router with the first version external antennas
  • Not compatible with AT&T US carrier
  • The advanced version of GL-X750
  • Redesigned PCBA and optimized antennas
  • More CAT4/CAT6 modules are available including the EG25-G global version
  • The version with EC25-AF module is AT&T IoT certified
Easy Installation
We also design a wall mount for installation on different surfaces. It helps you to acquire better Wi-Fi signal and keep places tidy.
Application Scenarios
Mass Wi-Fi Connectivity for Co-Working Space
Healthcare GL-X750
Connecting BLE Medical Simulation Packages to the Internet
Learn More
Internet Service Providers Offering Cellular Network for Vehicles
Vehicle GL-X750V2
Learn More
4G LTE Module
4G LTE
Module
External Storage
External
Storage
Dual-band Wi-Fi
Dual-band
Wi-Fi
VPN Client / Server
VPN Client /
Server
Specifications
1 x LAN Ethernet port
5 x LEDs
1 x USB 2.0 port
1 x Micro SIM card slot
1 x MicroSD card slot (Up to 128GB)
1 x Reset Button
CPU QCA9531@650MHz
Memory / Storage DDR2 128MB / NOR Flash 16MB
Protocol IEEE 802.11a/b/g/n/ac
3G/4G Mini PCIe Module Support CAT4/CAT6 Mini PCIe
Wi-Fi Speed 300Mbps (2.4GHz), 433Mbps (5GHz)
4G LTE Antennas 2 x detachable external antennas (SMA, 700M~2700MHz)
Wi-Fi Antennas 2dBi 5G & 2.4G internal antennas
TX power <20dBm
Ethernet Speed 10/100Mbps
LEDs Power / 2.4G Wi-Fi / 5G Wi-Fi / 4G / WAN
Power Input DC4017, 12V/1.5A (4.0*1.7mm)
Power Consumption <6W
Storage Temperature -20~70°C (-4~158°F)
Dimension / Weight 115 x 74 x 22mm / 86g
Tools & Downloadables Datasheet | Firmware | App | Tutorials | Media Kit
Looking for Bulk Purchase?
Contact Our Sales Manager
Frequently Asked Questions
Overall rating: 5.0 / 5 from 11 reviews.
AI Generated Review Summary
Summary topics
Review topics: ["software","works","router"].
Review highlights
Reviews
Good portable lte router
"Router works as expected with only one minor issue. On startup it takes about a couple minutes but other than that it works great. Follow the directions and the lte configuration is easy, another great product from a great company. My personal favorite among the travel routers is the flexibility of tethering or connecting to exsisting networks such as hotspots or free wifi spots"
Christopher G. (5/5)
Reliable product with excellent support
"Great device, great software. And when i was having a problem the support was always there to solve the problem."
Acrm (5/5)
It just works!!
"Easy to configure and it just works very well. Fail over between ethernet WiFi and 4G is quick."
Jeff P. (5/5)
Super router
"Small, yet powerful router. The OpenWrt software makes it very flexible. SIM is working smoothly."
Stefaan B. (5/5)
I am very pleased with
"I am very pleased with my purchase of a Spitz GL-X750V2 Smart WiFi Dual Band Router from GL. iNet. The transaction for the purchase of the router was entirely painless (out of Hong Kong, I believe) and the router turned up in my US mailbox slightly sooner than expected. The router was very easy to setup and its performance has been outstanding, especially since we live in a slightly remote area where Internet performance via SIM cards is not always great. I am 100% satisfied with my Spitz GL-X750V2 Router, thank you. Excellent service and an excellent product."
Guest C. (5/5)
Great product!
"Easy to setup. Runs on OpenWrt which is great. Only complaint I have is 4G SIM card does not automatically detect carrier’s APN otherwise it’s perfect."
Chun-Hsun W. (5/5)
Just what I needed
"Using this router for rural internet access. It works great and the software that is used to configure the router has all the bells and whistles you need."
William G. (5/5)
As good as advertized
"As good as advertized"
Gerard S. (5/5)
Nice little stationary cellular router
"This is the second one of these that I have owned. My previous one was the V1 and it still works, but all of the LEDs are flaky on it. I used it for a year or so like that so I expect this one to last a while. I'm hoping they fixed the LED issue on the "redesigned PCB". I wish they would still make a router like this one: small and light. The Spitz 5G is huge and all the antennas make it appear quite obnoxious. I use this one at my corporate job so that I can bypass the firewall for testing things as though I was on a public Wi-Fi. So it needs to be fairly nondescript. Be aware that this router has only 16MB of flash, so the firmware had to be trimmed of various features to make it fit. There are other open source firmwares you can get for it that won't have the GL custom stuff and so everything you need fits in the flash space. The EP06 is also blocked by Verizon for some reason. That's easy enough to fix if you Google the problem."
Aaron B. (5/5)
Very good product
"Very good product"
Saber (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
