$119.99
Original price $119.99 - Original price $119.99
$119.99
Current price $119.99
Wi-Fi 6 Gigabit Wireless Router
MEET Slate AX
Wi-Fi 6 Gigabit Router in Your Pocket
Wi-Fi 6 Travel Router
Slate AX (GL-AXT1800) is our first Wi-Fi 6 travel router that comes with IPQ6000 1.2 GHz quad-core processor. With the latest Wi-Fi 6 technology, you can enjoy more capacity for connected devices and faster wireless speed on the road or at home.
Max. 600 Mbps (2.4 GHz) + 1200 Mbps (5 GHz) Fast Wi-Fi Speeds
OpenVPN speed up to 560 Mbps (with DCO support); WireGuard speed up to 550 Mbps
Support Openwrt 23.05, DFS,  and file sharing
Learn More View Online Guide
Runs on OpenWrt 23.05
Slate AX runs on the latest OpenWrt 23.05 operating system (Kernel version 4.4.60), with mass device connection capabilities, and significantly reduced signal interference. You can customize the router and install applications based on your preferences.
Fast and Secure Browsing with VPN Encryption
Supporting OpenVPN and WireGuard®, Slate AX allows you to browse securely when on public Wi-Fi, work remotely when abroad, and access geo-restricted sites. Set up your VPN on the admin panel and shield the network on all connected devices. With saved settings, you won't have to set it up again every time.
WireGuard
Max. 550 Mbps
OpenVPN (with DCO support)
Max. 560 Mbps
30+ Commercial VPN Provider
Sophisticated Hardware Design
Slate AX is engineered to be a powerful and efficiently compact device. Its retractable antennas are both powerful and space-efficient for travel-friendly storage, and its enclosure holes pattern is both eye-catching and perfect for heat dissipation.
The device comes with a powerful CPU, Type-C power supply, USB 3.0 port, 3 gigabit ports, and a TF card slot that supports up to 512GB. Slate AX is ideal for file sharing and installing third-party applications that suit your needs.
GL-AXT1800 Ports
Portable Wi-Fi 6 Router
Slate AX offers powerful Wi-Fi 6 network connection with a dual-band combined Wi-Fi speed of 1800 Mbps (600 Mbps for 2.4 GHz and 1200 Mbps for 5 GHz). Enhance Wi-Fi performance with MU-MIMO, OFDMA, BSS color and able to connect to up to 120 devices simultaneously.
Our local network storage feature supports SAMBA and WebDav protocol. By plugging an external USB hard disc into the router, you can create a private network to store and share your documents. No matter for work or family, you can benefit from easy file access. Save space on your devices by storing photos and videos on the network; you can also use NAS to backup all your files to prevent data loss.
Portable Wi-Fi for Frequent Travelers
Protect Your Privacy on Public Wi-Fi Network
Wi-Fi 6 Coverage for Your Sweet Home
DFS Certification in US, UK, Europe & Japan*
Slate AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5 GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications. The selection of additional channels can lower network congestion under high density network environments.
*5G Wi-Fi Band 2 (5250Hz-5350Hz) is currently unavailable in Japan
Use Slate AX together with the GL-M2 Development Board which is designed to connect you to a 5G network and give you the internet you deserve. With a built-in SIM card slot, the GL-M2 Development Board serves as a 5G modem for your router to get your internet up and running, whether you are residing in a remote area with no internet access or traveling on the road. Even better, the GL-M2 Development Board features multi-WAN, supporting failover and load balancing to keep you connected at all times.
Learn More
WPA3 protocol
DNS over HTTPS & DNS over TLS
AdGuard Home
IPv6
Despite its compact size, the Slate AX has enough power to support heavy Wi-Fi usage and is sufficient for a family or small office. The router’s compact design makes it easy to deploy and it provides the kind of convenience and security that power users on the move will appreciate.
forbes
This fantastic little VPN router allows you to access a portable hard drive, an external SSD, a USB Flash Drive or a microSD card without wires.
techradar
Selling itself as a portable router, it holds up well against standard gaming router options, which we wouldn’t expect from something designed on the go.
pcguide
Slate AX (GL-AXT1800) Reviews
  • Video 1
    Set Up Secure VPN in Minutes with GL.iNet Routers!
  • Video 1
    Why You Need a Pocket Router: Hotels, Airports, Airplanes, Cruise Ships - Stay Connected Anywhere!
  • Video 1
    Travel Router - Do you really need it? GL.inet 1800 Review
  • Video 1
    Slate AX Travel Router to Fool your Boss and Stay Safe
  • Video 1
    Wireless Charging That Doesn’t Suck - Qi 2
  • Video 2
    Travel VPN WIFI 6 Router : GL-iNet Slate AX Pocket Size
  • Video 3
    GL.iNet GL-MT3000 and GL-AXT1800 Wi-Fi 6 Travel Routers
  • Video 3
    Product Review GL.iNet Slate AX Travel Router
  • Video 3
    Slate AXT1800 WiFi 6 Router Review | Compact Yet Powerful Router You Can Buy In 2022!
  • Video 3
  • Video 3
    Melhor Router para Viagem com Wifi 6! Segurança e Privacidade! | GL.iNet Slate AX (GL-AXT1800)
  • Video 3
    Use Home IP Address While Traveling with GL.iNet AX Slate, Opal, and WireGuard® VPN
  • Video 3
    GL.iNet GL-SFT1200 vs GL-AXT1800: Which Router is Best for Travel?
  • Video 3
    Schnelle Reise-Router - GL.iNet Slate AX und Slate Plus im Doppeltest
  • Video 3
    Which GL.iNet travel router is best for you?
  • Video 3
    Why This WiFi 6 Router Could SAVE Your Next Trip! GL.inet AXT1800
  • Video 3
    Gl Inet Slate AX GL AXT1800 Unbox Setup Captive Portals
  • Video 3
    Must-haves for IAM pros working remotely | Ep. 155
  • Video 3
    Ce Que J'Emmène Toujours en Vacances - Gadgets Indispensables pour l'Été!
  • Video 3
    DAS sagt KEINER über STARLINK MINI im Wohnmobil
  • Video 3
    WHY YOU NEED A TRAVEL ROUTER - HOTEL'S , CRUISE SHIPS, AIRPORTS...
  • Video 3
    The TRUTH About Travel Routers: What You Need to Know!
Wi-Fi 6
Wi-Fi 6
Gigabit Ethernet
Gigabit
Ethernet
Type-C Power Port
Type-C
Power Port
USB 3.0 Port
USB 3.0
Port
OpenWrt Pre-installed
OpenWrt
Pre-installed
VPN Client/Server
VPN Client /
Server
AdGuard Home
AdGuard
Home
AdGuard Home
Multi-User
MIMO
DFS
DFS
Local Network Storage
Network
Storage
Specification
2 x LAN Ethernet ports
1 x USB 3.0 port
1 x Type-C power port
1 x MicroSD card slot (Max.512GB)
1 x Reset button
1 x Toggle button
CPU IPQ6000 1.2 GHz Quad-core Processor
Memory / Storage DDR3L 512MB / NAND Flash 128MB
Protocol IEEE 802.11a/b/g/n/ac/ax
Wi-Fi Speed 600Mbps (2.4 GHz), 1200Mbps (5 GHz)
Antennas 2 x undetachable external Wi-Fi antennas
Power Input Type-C, 5V/4A
Power Consumption <8.75W
Dimension / Weight 125 x 82 x 36mm / 245g
Looking for Bulk Purchase?
Contact Our Sales Manager
Frequently Asked Questions
Overall rating: 4.878049 / 5 from 123 reviews.
AI Generated Review Summary
The Slate AX Wi-Fi 6 Travel Router offers a powerful and compact solution for fast and secure internet connectivity on the go. Its intuitive interface and excellent performance make it ideal for both home and travel use. The router provides seamless Wi-Fi 6 speeds, advanced security features, and a user-friendly setup process.
Summary topics
  • User Interface (8%): Customers raved about the user-friendly and intuitive web interface of iNet's product.
  • Performance (9%): Customers keep praising the excellent performance of the router, making it a great choice for home or small office use.
  • Wi-Fi Speeds (13%): Customers raved about the fast speeds and seamless connectivity provided by the Wi-Fi 6.
  • Portable Wi-Fi Connection (5%): Customers keep praising the powerful and portable Wi-Fi 6 travel router with advanced security features.
  • Compact Size (8%): Customers expressed appreciation for the small size of the device, which fits perfectly in a bag.
Review topics: ["fit","size","quality","works","value","delivery","service","price","support","speed","setup","issues","performance","interface","connection","use","features","wifi","balance","router","design","device","vpn","experience","capabilities","range","unit","team","network","configuration"].
Review highlights
  • "I love the device size and weight plus the service provided is what I acquired it to do."MARVIN W.
  • "Love the fast speeds and von capabilities."Robbie H.
  • "This router is a very powerful device in a nice, compact size."Mark M.
Reviews
Very Stable Router
"Deducted 1 star because, I found out that, their root operating system OpenWrt, is an old copy. GL-inet has not yet updated their firmware to the most up-to-date OpenWrt version 25. 12. 5"
NIRAV S. (4/5)
Great technical support
"Great technical support when troubleshooting WireGuard VPN connection within Slate AX! Special thank you to Barry :)"
Alex Z. (5/5)
Awesome home router
"Works beautifully"
Eliza P. (5/5)
Love my travel Router
"I had the best experience with Zenia! She was very helpful and knowledgeable!. I will always recommend Gl inet! 10 out of 10!"
jt (5/5)
Perfect for remote working
"Works extremely well, able to use in various countries!"
R H. (5/5)
"super service, great product"
Attila (5/5)
Slate AX (GL-AXT1800) Wi-Fi 6 Gigabit Wireless Travel Router
"An excellent trading experience in every respect. The Slate AX (GL-AXT1800) Wi-Fi 6 Gigabit Wireless Travel Router performs brilliantly and is easy to set up. It is a high-quality device with commendable security features and customizability for one's own operating environment."
Jari E. (5/5)
These are definetly some
"These are definetly some of the best routers sold. And the support is pretty awesome i would say the best. The only downside is I am in the U. S. so sometimes the support responds from an international time zone. But they always respond and they always help, you can tell they are tech people. Great products all the time."
Salvatore (5/5)
Small, reliable, and simple to use
"The Slate AX definitely exceeded my expectations. I travel a lot for work and never even thought of the idea of a travel router or knew that it existed. I needed a reliable way to connect to my home network that was safe and easy to transport. This hit every requirement for me. I was blown away with how quick and easy this was to be able to setup and use. It connects effortlessly to hotel wifi and does exactly what it is supposed to do! I do not leave on a work trip without it!"
Tommy A. (5/5)
Go for Slate AX!
"I upgraded to the Slate AX from the Opal, and the experience is definitely noticeable. So far I haven't found an a Wi-Fi connection that the Slate AX won't connect to, unlike the Opal. This router has accompanied me an several trip and an international trip as well. The VPN capability with NordVPN and my own personal VPN server was very seamless and easy to setup. The hotel portal feature in order to connect to hotel Wi-Fi has worked great as well. Pairs great with a compact USB drive to plug into the back for file sharing or loading movies onto. Overall great product that I would recommend for any traveler who wants peace of mind with their network or even if someone needs a temporary router while moving."
Logan (5/5)
Q&A
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
