White / GL-AR150
GL-AR150 Mini Smart Router
MEET WHITE
Mini Smart Router for Commercial IoT Applications
Discontinued
Mini Smart Router
White (GL-AR150) has mini size and travel-friendly, which is applicable for small enterprise, business and family scenarios. It’s your best choice that provide internet surfing together with wireless.
150 Mbps Wi-Fi Speed
1 x 2.0 USB Port
1 x Toggle button
2 x Ethernet Ports
Support PoE (Optional)
Learn More View Online Guide
Your Security is Our Priority
Added Security to Help You Stay Secure on Public Wi-Fi
Travel-Friendly
Converting a public network (wired/wireless) to a private Wi-Fi for secure surfing. Tethering, 3G/4G USB Modem Compatible. Only 39g (1.41 Oz) and very pocket-friendly.
4 Ways to Access the Internet
Mango can be connected to the Internet through Ethernet cable or wireless repeater
Internet Connection - Ethernet
1. Ethernet
Internet Connection - Repeater
2. Repeater
Internet Connection - USB Modem
3. USB Modem
Internet Connection - Tethering
4. Tethering
Work or Play Securely Anywhere, and Anytime
Apart from its powerful built-in firewall, White (GL-AR150) also supports OpenVPN, WireGuard and customized DNS server in order to level up your online security. With our brand-new Web UI 3.0, you can set up VPN server easily and access your files securely and remotely as if you were at home.
WireGuard® is a registered trademark by Jason A.Donenfeld.
WireGuard
Max. 35Mbps
OpenVPN
Max. 7Mbps
Web UI
Cloudflare
ENCRYPTED DNS WITH CLOUDFLARE
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. The goal of the method is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Visit Cloudflare
Cloudflare x GL.iNet
PoE Power Supply
You can only use one power supply method at one time, either via PoE (Power over Ethernet) or micro USB cable. The PoE injector should be compatible with active or passive 48V 802.3af standard. PoE only works on the WAN port.
PoE
Similar Model Comparison
GL-AR150
GL-AR150
GL-AR150-PoE
GL-AR150-PoE
GL-AR150-Ext
GL-AR150-Ext
GL-AR150-Ext-PoE
GL-AR150-Ext-PoE
16MB Nor Flash
PoE
External Antennas
Travel-Friendly
Travel-Friendly
VPN Client/Server
VPN Client /
Server
PoE (Optional)
PoE
(Optional)
External Antennas
External Antennas
(Optional)
Specifications
1 x LAN Ethernet port
3 x LEDs
1 x USB2.0 port
1 x Micro USB power port
1 x Reset button
1 x Toggle button
CPU Atheros9331, @400MHz SoC
Memory / Storage DDR2 64MB / NOR Flash 16MB
Protocol IEEE 802.11b/g/n
Wi-Fi Speed 150Mbps (2.4GHz)
Ethernet Speed 10/100Mbps
LEDs Power / Wi-Fi
Power Input Micro USB, 5V/2A
Power Consumption <1.5W
Dimension / Weight 58 x 58 x 25mm / 40g
Tools & Downloadables Firmware | App | Tutorials
Looking for Bulk Purchase?
Contact Our Sales Manager
  • Free Local Shipping
    Fast delivery
  • Rewards on Every Order
    2 points for every $1 spent
  • 2-Year Warranty
    Reliable product coverage
  • 30-Day Returns
    Fast and easy refunds
