Compact Thread Border Router for IoT
GL-S20 is a compact and cost efficient Thread Border Router designed for fast and simple IoT deployment. It supports Thread 1.3 as well as 2.4 GHz Wi-Fi (150Mbps) and ethernet for building a Thread Network and connecting to the Internet. The GL-S20 is equipped with the high-performance ESP32 chipset and is fully compatible with FreeRTOS. It supports Wi-Fi to Ethernet Failover, ensuring optimal performance and reliability. Additionally, the GL-S20 features PoE functionality, making it a versatile solution for various IoT.
Wi-Fi speed up to 150Mbps (2.4GHz)
Supports Wi-Fi to Ethernet Failover
Features PoE functionality
Flexible Thread roles within your network
GL-S20 can seamlessly operate as a Thread Border router or a Thread router. This functionality offers added flexibility to your IoT setup and adapts to your ever-evolving IoT needs, whether it's to extend the network reach or connect to external networks.
Ease of installation with support for PoE
By integrating Power over Ethernet (PoE), GL-S20 transmits power and data over a single ethernet cable. You’ll have power to more areas without having to install additional electrical infrastructure—saving on extra costs in the long run.
Your pathway to a scalable IoT network
Manage and control all your IoT devices effortlessly with GL-S20, the ultimate solution for building a robust, scalable network for all your IoT devices. GL-S20 when used as a Thread Border router bridges your LAN network and other GL-S20s functioning as Thread routers seamlessly. GL-S20’s self-healing capability ensures a resilient network infrastructure, even in the face of network disruptions. In case one of the Thread routers fails unexpectedly, the network reconfigures automatically using a neighboring Thread router, ensuring your connection remains rock-solid at all times.
Built on FreeRTOS
GL-S20 runs on the reputable kernel FreeRTOS, the de facto standard for microcontrollers and small microprocessors. FreeRTOS is well-supported by a broad community, offering exceptional customization capabilities with add-on libraries that are ever-growing.
ESP32 Series chipsets
GL-S20 is powered by ESP32-S3 and ESP32-H2 chipset. While ESP32-H2 acts as the radio co-processor, ESP32-S3 serves as the main chip, designed provide enhanced capacity for expanding your IoT network. It also boasts ultra-low power consumption and steadfast performance in industrial environments.
Flexible Installation
Included in the GL-S20 package is a wall mount kit, making it effortless to mount on the wall. The GL-S20, with its lightweight and compact design in a sleek white color, can seamlessly fit into any space. This feature not only frees up surface area but also ensures exceptional coverage and uninterrupted connectivity for your IoT devices.
FreeRTOS
Thread
Wi-Fi to
Ethernet Failover
PoE
Specification
Interface | 1 x Ethernet port 1 x Reset button 1 x IoT button |
CPU | ESP32-S3 Dual-core, @240MHz |
Memory / Storage | SRAM 512KB + PSRAM 8MB / Flash 16MB |
Protocol | Supports Thread 1.3 Supports BLE 5.0 Supports Wi-Fi 802.11b/g/n (2.4GHz) |
Wi-Fi Speed | 150Mbps (2.4GHz) |
Ethernet Speed | 10/100Mbps |
LEDs | Power / IoT / Network |
Power Input | Type-C, 5V/1A or PoE, IEEE 802.3 af |
Power Consumption | DC power supply: <3W PoE power supply: <7W |
Operating Temperature | 0~40°C (32 ~ 104°F) |
Storage Temperature | -20~70°C (-4~158°F) |
Dimension | 76 x 76 x 25mm / 63g |
Tools & Downloadables | Datasheet | Firmware | Unboxing | Tutorials |
